Home > Message Board > Car Audio > Subwoofers > Archive through June 12, 2008 > CA.com
Author Thread: CA.com
Username: 420alldaylong
Post Number: 3659
A friend said something about box diagrams on CA.com
Since Im banned from there will someone check out the box diagram thingy.
Are the spec rite?.
Does/Has anyone use them?
Thanks
Username: Joebruce
TC Sounds/DLS
Post Number: 2146
Why are you banned?
Username: Ctmike
Ct.
Post Number: 6253
so when you get banned you can't view the site at all? thought you just couldn't re-register?
Username: Gibsonguy
Storrs, CT
Post Number: 156
if a website has banned your ip address, you can use a proxy site to access it usually. sometimes not all items on the site will function correctly but chances are you can still see what you want to.
just do a google search on proxy sites, and a bunch of them will pop up. then you can view ca.com through there.
nice job getting banned on a car audio site lol.
Username: The_image_dynamic
San Diego, California
Post Number: 4088
http://www.thefreeproxy.us/index.php?q=aHR0cDovL3d3dy5jYXJhdWRpby5jb20%3D&hl=3ed
Home > Message Board > Car Audio > Subwoofers > Archive through June 12, 2008 > CA.com [ « Previous ] [ Next » ]
