Thread: SUBS CUT OUT |
New member Username: Centurybangin
Post Number: 6 Registered: May-08
| Posted on Sunday, June 08, 2008 - 07:46 pm: |
Alright I just got two Alpine Type R's and they are powered by a kicker zx750.1 amp. The other day I was driving and out of nowhere the subs cut out. The amp is working fine, the green light is on. I can't think of any other reason for them to stop working except for that I changed the wires coming from the back of the box to the amp to a bigger grade wire than the one inside and forgot to change the wires inside the box. Could this have caused them to stop working? If not what else could it be? Thanks for all help |
Bronze Member Username: Neyetmare
Post Number: 27 Registered: Nov-07
| Posted on Sunday, June 08, 2008 - 07:54 pm: |
did you look at the wires inside the box at all? they could have came loose or something. |
Post Number: 7 Registered: May-08
| Posted on Sunday, June 08, 2008 - 07:57 pm: |
Ya I took them out and looked at them they looked fine |
Silver Member Username: Hittin1
Lake Charles,
La.
United States
Post Number: 445 Registered: May-07
| Posted on Sunday, June 08, 2008 - 08:05 pm: |
check amp... (ground,rca,ect..) "The amp is working fine, the green light is on." amp can still be bad or at least have problems. |
Gold Member Username: Van_man
Boston South,
MA
Post Number: 4024 Registered: Mar-06
| Posted on Sunday, June 08, 2008 - 10:33 pm: |
use a circle jig in your rotor. |
