Thread: Door deadening |
Diamond Member Username: Bestmankind
Post Number: 21211 Registered: Oct-05
| Posted on Sunday, June 08, 2008 - 02:22 pm: |
alright so here's the deal. i already deaden my doors so they are good. the problem is the door panel is making some rattle sound. it bothers me. i am an*l retentive when it comes to car audio so every little thing bothers me. now my idea is applying dynamat to the inside of the door panel. has anyone done it? |
Gold Member Username: Ctmike
Ct.
Post Number: 6247 Registered: Feb-06
| Posted on Sunday, June 08, 2008 - 03:19 pm: |
i've done it. friend had me do it for his car, came out really nice. went cheap with edead v1, almost 2 layers on the door and then 1 layer on the inside of the panel. really helped. not only did it help sound wise, but it also makes it damn near impossible for the wind to blow the door open hard. gives it a really nice heavy thud when you close it |
Post Number: 21212 Registered: Oct-05
| Posted on Sunday, June 08, 2008 - 03:40 pm: |
just what i wanted to hear. thaks mike. |
Platinum Member Username: Rovin
1 15 = 149.1DBs Trinidad & T...
Post Number: 13875 Registered: Jul-05
| Posted on Monday, June 09, 2008 - 12:43 am: |
im having that same problem chad & i need to mine soon - aaaah but u know whats it like to be in a lazy azz mood to do a certain task sometimes ..... |
