Home > Message Board > Car Audio > Accessories > Archive through September 24, 2008 > LOC wiring help
Author Thread: LOC wiring help
Username: Skateguy92
Post Number: 8
I lost the book to my LOC and Ive never messed with them before. Im hooking up a couple subs and amp to a stock H/U lexus es300... I know you just have to tap into the rear speakers into the LOC then RCA to amp.
Question is... Do I just need to hook the rear +/- wires into the "input" side of the LOC? Or do I need to tap into the "input" side and then go back to the rear speaker from the "output" side?
Username: Howtoeatapencil
Post Number: 153
I think u would want to run the output side to the rear speakers? And thun run the RCA outsputs to your amp
Post Number: 9
Well the LOC has two sides with room for 4 speakers... a input side and a output side.
My thinking was I just needed the signal to the LOC therefor I would have no need to have any wires in the output side of the LOC. I was thinking just tap into the speaker wire +/- and run the tap the input side of the LOC and the RCA rear output to the RCA on my amp.
Post Number: 157
sounds like it would work? maybe try it see if it does
Home > Message Board > Car Audio > Accessories > Archive through September 24, 2008 > LOC wiring help [ « Previous ] [ Next » ]
