Thread: Kinetiks or Optima Yellow Top & Why |
Silver Member Username: Audiosaab
Potomac,
MD
Post Number: 171 Registered: Nov-07
| Posted on Friday, June 06, 2008 - 11:19 am: |
Trying to decide between the two brands and figured id ask opinions |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7641 Registered: Jul-06
| Posted on Friday, June 06, 2008 - 11:32 am: |
Neither. www.odysseybatteries.com But if it has to be between those two Kinetik wins by a mile. |
Potomac,
MD
Post Number: 172 Registered: Nov-07
| Posted on Friday, June 06, 2008 - 12:16 pm: |
alright cool and how precisely do i wire up a second battery to my original? (EX: size wiring, how much, how to wire it so the 2nd is in my trunk) |
Silver Member Username: Boomtank
Rochester,
NY
Post Number: 577 Registered: Oct-06
| Posted on Friday, June 06, 2008 - 12:19 pm: |
I'd do atleast one run of 1/0 gauge from the positive of the front battery to the positive of the back battery. Then either ground the second battery to the chassy or if you have the money do a run from the negitive front to the negitive back. |
Potomac,
MD
Post Number: 173 Registered: Nov-07
| Posted on Friday, June 06, 2008 - 12:24 pm: |
will it charge if i only run the pos and then ground? sorry, new to the whole battery thing..............and also if im running a 1400-1600rms estimated watt amp what size kinetik battery do i want? there saying the HC1800 but i doubt i need that much juice. p.s im going to be running this off of the big 3 wiring under the hood as well as the two batts and a stock 90amp alternator |
Northwest PA
Post Number: 7643 Registered: Jul-06
| Posted on Friday, June 06, 2008 - 01:43 pm: |
The two batteries have to be the same to wire them in parallel like that. Otherwise you need an isolator and then you still only have one battery on the audio system anyway. WHY are you wanting the 2nd battery? If you're having electrical issues that 90 amp alternator is the problem. Batteries are not a substitute for an alternator. One good battery (kitetik, odyssey, etc) is more than enough for a daily system. You need an alternator that can keep it charged though.
Silver Member Username: Durski
Post Number: 423 Registered: Nov-06
| Posted on Friday, June 06, 2008 - 01:50 pm: |
Would the system suffer if you only upgrade the Alt and Big 3 but leave the factory battery in place? |
Northwest PA
Post Number: 7646 Registered: Jul-06
| Posted on Friday, June 06, 2008 - 01:53 pm: |
Often thats enough if you're not running a huge amp. For 3kw+ it's good to have a better battery though. |
Potomac,
MD
Post Number: 175 Registered: Nov-07
| Posted on Friday, June 06, 2008 - 02:04 pm: |
O, the tech support told me i should upgrade my battery, i thought this meant that i should get a second....but mabye ill look into just replacing my existing stock one......on top of this i am going to eventually replace the alternator but not quite yet..... like i said im new to this but like i said ive already done the big 3.... |
Gold Member Username: Tatonka
-[Team Audib...
Post Number: 1795 Registered: Mar-07
| Posted on Friday, June 06, 2008 - 04:21 pm: |
"and also if im running a 1400-1600rms amp" You DO NOT need a HO alt if you are running that much power if the amps have any efficiency to them at all. Just do you big three and put a kenetik 2000 or so in the back and you will be good to go man. |
Post Number: 425 Registered: Nov-06
| Posted on Friday, June 06, 2008 - 05:03 pm: |
^ "You DO NOT need a HO alt if you are running that much power" I disagree. I think it comes down to an individual basis, I was running 330rms on a crappy amp and my lights dimmed when the bass hit, now I'm running 1200rms on a better amp and the amp has shut off a few times when I turn it up loud. I have a HO alt on the way, but have not yet done the big 3. I doubt the big 3 alone will give me the extra power to make my system run with minimal voltage drops. I'm no expert, but I believe the problem I am having is related to the power I supply my amp, and if you want to run higher rms then you will most likely encounter similar issues with out a HO Alt. |
-[Team Audib...
Post Number: 1796 Registered: Mar-07
| Posted on Friday, June 06, 2008 - 05:05 pm: |
I disagree. I know that you can run 2krms off a stock alt with an extra battery if you have all the correct wiring and a decent amp. |
Silver Member Username: Denim
SoundSolutionsAudio.com,
MD
Post Number: 730 Registered: Nov-06
| Posted on Friday, June 06, 2008 - 05:09 pm: |
Also look into PowerMaster and SVR for batteries. |
-[Team Audib...
Post Number: 1797 Registered: Mar-07
| Posted on Friday, June 06, 2008 - 05:11 pm: |
Yes, I have heard nothing but great things from power master batteries. Just see what you can get some decent deals on. |
Gold Member Username: Talon01
Team Revolution ,
Pa
Usa
Post Number: 1346 Registered: Jun-07
| Posted on Friday, June 06, 2008 - 05:15 pm: |
it comes down to effi. chris, nick is right that 330w was probally dirty power aka high resistence. i was running 600w and it dimmed my lights with 136a alt so i upgraded to a optima yellow top and it helped some so i got a 300a alt it was much better. then i switched amps to a 3800w quess what no light dimming because the amp was more effi. |
Gold Member Username: Insearchofbass
Post Number: 9466 Registered: Jun-04
| Posted on Friday, June 06, 2008 - 05:16 pm: |
chris Durski...."I disagree. I think it comes down to an individual basis, I was running 330rms on a crappy amp and my lights dimmed when the bass hit, now I'm running 1200rms on a better amp and the amp has shut off a few times when I turn it up loud. I have a HO alt on the way, but have not yet done the big 3. I doubt the big 3 alone will give me the extra power to make my system run with minimal voltage drops. I'm no expert, but I believe the problem I am having is related to the power I supply my amp, and if you want to run higher rms then you will most likely encounter similar issues with out a HO Alt." while I agree with the facts you gave Chris you missed that nick said a "kenetik 2000 or so in the back" and I agree with that statement but only would do that for a daily system if the stock alternator was big enough to support the battery |
Team Revolution ,
Pa
Usa
Post Number: 1347 Registered: Jun-07
northstar battery nsb90 end of discussion |
-[Team Audib...
Post Number: 1798 Registered: Mar-07
| Posted on Friday, June 06, 2008 - 05:19 pm: |
"and I agree with that statement but only would do that for a daily system if the stock alternator was big enough" Yeah. My stock alt is 110 amps or so Sean. But on a 3 second burp for SPL, your alternator doesn't actually come into play. It is all battery power. With one kenetic 2400 on 2k my voltage was actually staying around 13v or so with a 53hz burp. Surprised me. |
Post Number: 9467 Registered: Jun-04
| Posted on Friday, June 06, 2008 - 05:22 pm: |
but at the same time a ho alt with sufficient idle amperage would also do the job well |
-[Team Audib...
Post Number: 1799 Registered: Mar-07
| Posted on Friday, June 06, 2008 - 05:24 pm: |
Yes, but the discharge rate from the alt would not be enough to rely on. |
Post Number: 9468 Registered: Jun-04
| Posted on Friday, June 06, 2008 - 05:27 pm: |
"With one kenetic 2400 on 2k my voltage was actually staying around 13v or so with a 53hz burp. Surprised me." oh im not suprised....ive seen my brother's kinetic hold on more power than that (2800 I think) at 63 hz and stayed in the 13.3 volts range and that was only a kinetic 1800 I think |
-[Team Audib...
Post Number: 1800 Registered: Mar-07
| Posted on Friday, June 06, 2008 - 05:29 pm: |
Yeah man. I was burping 4k last night on that one kinetic 2400 and voltage did not get low at all. |
Post Number: 9469 Registered: Jun-04
| Posted on Friday, June 06, 2008 - 05:30 pm: |
"Yes, but the discharge rate from the alt would not be enough to rely on." for daily use? |
-[Team Audib...
Post Number: 1801 Registered: Mar-07
| Posted on Friday, June 06, 2008 - 05:32 pm: |
I thought you meant for burps Sean lol. I would still get an upgraded bat for daily use... |
Post Number: 9470 Registered: Jun-04
| Posted on Friday, June 06, 2008 - 05:34 pm: |
"Yeah man. I was burping 4k last night on that one kinetic 2400 and voltage did not get low at all." nice....by the way my bro's notherstar is even better than that kinetic and its not even brand new....it was previously used in ray farmers crx on two dd z 10's |
Post Number: 9471 Registered: Jun-04
| Posted on Friday, June 06, 2008 - 05:38 pm: |
"I thought you meant for burps Sean lol. I would still get an upgraded bat for daily use..." I thought so I probably would do the ho alt but to each his own |
-[Team Audib...
Post Number: 1802 Registered: Mar-07
Really man? I never heard much about North Star. Soon I will be getting a HO and and upgrading my start bat, but that is after I spend all this money on paint for the exterior ;) |
Post Number: 9472 Registered: Jun-04
| Posted on Friday, June 06, 2008 - 05:42 pm: |
"Really man? I never heard much about North Star. Soon I will be getting a HO and and upgrading my start bat, but that is after I spend all this money on paint for the exterior ;)" yeah it was either the kinetic 1800 or the 2400 that he was using and the northstar held the voltage a little stronger (didnt drop as fast) and like I said that was a used northstar that had 4000 to 5000 watts drawn off of it (car off) in Ray farmers crx on two dd z10's |
Post Number: 426 Registered: Nov-06
| Posted on Saturday, June 07, 2008 - 01:02 am: |
I did miss that part about the extra kenetik, I stand corrected. But 110 idle for a stock alt is amazing compared to my 65amp alt at 1800 rpm, not at idle. I think the alt I have on the way is 85 idle and 135amp at 2000rpm... I can double check specific number if anyone else have an Accord they are lookin to get more juice out of. I can't stop you from laughing at this, but it will give some insight as to why 4 times the power only made my problem slightly worse, replaced a sony amp with a kicker. |
Post Number: 9479 Registered: Jun-04
| Posted on Saturday, June 07, 2008 - 07:16 am: |
chris Durski...."I did miss that part about the extra kenetik, I stand corrected. But 110 idle for a stock alt is amazing compared to my 65amp alt at 1800 rpm, not at idle." Nick was talking 110 max not at idle "I think the alt I have on the way is 85 idle and 135amp at 2000rpm... I can double check specific number if anyone else have an Accord they are lookin to get more juice out of." to me the idle amperage is important because thats the worst case situation "I can't stop you from laughing at this, but it will give some insight as to why 4 times the power only made my problem slightly worse, replaced a sony amp with a kicker." that probably made a difference  |
Gold Member Username: Van_man
Boston South,
MA
Post Number: 4019 Registered: Mar-06
| Posted on Saturday, June 07, 2008 - 09:24 am: |
Whats the legal issues of using a NSb90 in the lanes. It is a telcom battery, therefor it may not be legal. Anyone know if they are approved? |
Team Revolution ,
Pa
Usa
Post Number: 1349 Registered: Jun-07
| Posted on Saturday, June 07, 2008 - 09:50 am: |
the nsb g3100 is legal. thats what i have its the same battery it even says nsb90 in small letters. |
Gold Member Username: Th3pwn3r
I compensate...
Post Number: 8198 Registered: Jul-06
| Posted on Saturday, June 07, 2008 - 10:58 am: |
Odyssey batteries are not the most cost effective. You can find Kinetiks of comparable performance for far less however, the NSB batts beat out both the Odyssey batts and Kinetiks in a power per dollar ratio. |
I compensate...
Post Number: 8199 Registered: Jul-06
| Posted on Saturday, June 07, 2008 - 11:02 am: |
"yeah it was either the kinetic 1800 or the 2400 that he was using and the northstar held the voltage a little stronger (didnt drop as fast) and like I said that was a used northstar that had 4000 to 5000 watts drawn off of it (car off) in Ray farmers crx on two dd z10's " Don't forget it's all about how you "train" the batteries. |
Post Number: 9483 Registered: Jun-04
| Posted on Saturday, June 07, 2008 - 11:07 am: |
what do you mean by train Rob |
Silver Member Username: Deadrabit
Post Number: 409 Registered: Jun-07
| Posted on Saturday, June 07, 2008 - 12:05 pm: |
if u do the big 3 on a stock battery wont it damage it? |
Post Number: 9484 Registered: Jun-04
| Posted on Saturday, June 07, 2008 - 01:05 pm: |
no the big 3 will help with current delivery....sounds like your worried about too much voltage....thats the voltage regulator's job |
Gold Member Username: Mixmastaspig
Team RD,
Post Number: 1721 Registered: Sep-05
| Posted on Saturday, June 07, 2008 - 01:31 pm: |
Here is a question for you battery people: What is the largest, deep cycle, group 31 battery with side mounts that I could fit into a 94 Saturn SC2? If I get a battery larger than a group 31 I automatically get bumped up to street C, but in C you can run two batteries..... |
Silver Member Username: Quirky
SA,
Texas
Post Number: 259 Registered: Feb-07
| Posted on Saturday, June 07, 2008 - 02:16 pm: |
can someone drop a link to were you can find these batteries for sale? I cant even Google kinetic and find it. |
New member Username: Cd5honda96
OR
United States
Post Number: 1 Registered: Jun-08
| Posted on Saturday, June 07, 2008 - 07:39 pm: |
^^ Just check out ebay. |
Gold Member Username: Naledge503
LowDownForum.com
Post Number: 3855 Registered: Jun-06
| Posted on Saturday, June 07, 2008 - 07:52 pm: |
"can someone drop a link to were you can find these batteries for sale? I cant even Google kinetic and find it." Thats cause it kinetik.  |
