Home > Message Board > Car Audio > Subwoofers > Archive through June 07, 2008 > Kicker L5
Author Thread: Kicker L5
Username: Jakez07
Marana,
United States
Post Number: 9
Im looking to get two 12 inch kicker 08 L5's. They are actually within my budget ha. Anyways, i see theres a 2 ohm version and a 4 ohm version. Which should i get? Im tryin to spend least amount of money. And a good amp for them, that isnt exspensive? thankss.
Username: Bman365
With two of the 2ohm subs you can make them run 2ohm mono or 4ohm bridged. Two of the 4ohm subs you can make them run 1ohm mono.
Username: Rideredder
Cornell, IL
Post Number: 1431
What is your budget?
Is Kicker all that you have looked at? You can get better equipment for cheaper than those L5's are.
Ohm wise, it all depends on what you want to run the sub(s) at. If you want two subs, you could get the dual 4 ohm and run them at 1 ohm, or the dual 2 ohm and run them at 2 ohms. All depends on the amp.
Also, it depends on your cars charging system. What car do you drive and what size is the stock alternator?
Username: Jakez07
Marana,
United States
Post Number: 10
What would be better and cheaper?
i got a 84 mazda protege
Username: Nd4spd18
Northwest PA
Post Number: 7626
The square subs blow. IDK about cheaper but theres plenty better. Whats the budget here.
Username: Ctmike
Ct.
Post Number: 6234
if just going for cheap spl, then they are good. but if wanting better sq/lowend you can definately do better.
also, to let you know, l5s' can be bought for $150 shipped each (12") bnib from online dealers. though it's the '06 model, from everything i've read about them and the new ones is you wont notice any difference at all.
Username: Jakez07
Marana,
United States
Post Number: 11
Well then
What would you guys suggest around same price but better?
id say for subs i got like 350$
Username: 420alldaylong
Post Number: 3652
2 RE SE 12"
or
2 AQ SDC2.5 12"
on a AudioQue AQ1200D
Username: Jakez07
Marana,
United States
Post Number: 12
any other ones??
Username: Nd4spd18
Northwest PA
Post Number: 7636
I'd get the REs, they should be almost as loud, sound a lot better, and have a little better low end.
Diamond Member
Post Number: 21178
kicker L5 Upload
Home > Message Board > Car Audio > Subwoofers > Archive through June 07, 2008 > Kicker L5 [ « Previous ] [ Next » ]
