Thread: Bad Ground?? Help!! |
New member Username: 248vista
Post Number: 3 Registered: Jun-08
| Posted on Wednesday, June 04, 2008 - 11:14 pm: |
For you electrical gurus, how am i able to tell if a bad ground on my radio is causing it to shut off when I start to raise the volume > 20%? THanks |
Gold Member Username: Kpa2727
Old Bridge,
NJ
USA !
Post Number: 1334 Registered: May-07
| Posted on Thursday, June 05, 2008 - 01:11 am: |
just check it , the area where it's grounded should be clean and sanded and then the ground applied. also you can get a multimeter put it on dc voltage, touch the ground and a positive see if u get 12 volts or higher. or turn the radio on with a meter on it's positive and negitive and turn the radio up if voltage drops past 12 volts then you have a bad ground or a short. so thats about all you can do. the typical cause is your speakers are to large for the radio to power. |
Post Number: 4 Registered: Jun-08
| Posted on Thursday, June 05, 2008 - 01:14 am: |
Thanks Keith! Unfortunately this is the radio on my boat so I can't just sand and apply I will look at voltage drop as u indicated and see if this is my issue. |
Old Bridge,
NJ
USA !
Post Number: 1336 Registered: May-07
| Posted on Thursday, June 05, 2008 - 07:42 pm: |
hmm maybe try to tie into the batteries ground for the best result. |
