Home > Message Board > Car Audio > Subwoofers > Archive through June 07, 2008 > Cheap setup
Author Thread: Cheap setup
Username: 4realadeala
Tampa, Florida
Post Number: 47
My wife just got a new car and she isn't the happiest with the depth of the stock system. I am looking to put one 15 with about 300rms in there and a simple amp just to push it. Price range no more than 200 buckaroos. If you could please, when you start listing products tell me a good internet store to purchase them from also.
Thanks
Username: Audiosaab
Potomac, MD
Post Number: 169
Back in the day i used "Dual" brand subwoofers.... they worked pretty well held up to about 500-600rms or so for 2 12"ers....you can usually pick a box with 2 12"s pre installed at best buys and buy a cheap amp to push them for about 200..
Username: Snowball123
West Allis, WI
United States
Post Number: 798
no duals.
Username: Skibum12189
Cleveland
Post Number: 2911
elemental designs 13kv.2 and a kicker zx400.1 is all you need.
Username: Insearchofbass
Post Number: 9411
"no duals."
x2
A pic is worth
1000 posts!!
Post Number: 16948
"elemental designs 13kv.2 and a kicker zx400.1 is all you need."
I have 6.
Username: 420alldaylong
Post Number: 3649
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2961
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3168
Username: 04redmach1
Columbus, GA
Post Number: 2023
LMAO! Paul, I figured you would buy em' haha.
If the ed's are in stock still, can't beat the price on it :-)
Kevin
A pic is worth
1000 posts!!
Post Number: 16956
They're still available.
Username: Audiosaab
Potomac, MD
Post Number: 170
lol fair enough, just mentioned because he said cheap so i went with the true definition of "cheap"
Tampa, Florida
Post Number: 49
Thank you fellas, hey maybe GW will give us another stimulus break and I can get some GOOD stuff. Until then though Bumpin on a Budget.
Thank you for your time.
Username: Deadrabit
Post Number: 404
don't get dual.
i wouldn't get anything at walmart either.
kicker is prolly ur best bet
Home > Message Board > Car Audio > Subwoofers > Archive through June 07, 2008 > Cheap setup [ « Previous ] [ Next » ]
