Thread: Drive in movies |
Bronze Member Username: Jayhunter
New Haven,
IN
Post Number: 41 Registered: May-08
| Posted on Wednesday, June 04, 2008 - 12:50 pm: |
With an 1100 watt amp and an 800 watt sub, would I be able to sit through a drive in movie in my car without the battery dying? It seems waaaay too cool to go to a drive in and listen to it on a loud car audio system. |
Gold Member Username: Insearchofbass
Post Number: 9405 Registered: Jun-04
| Posted on Wednesday, June 04, 2008 - 03:24 pm: |
if you plan on playing it low and drawing 250 to 300 watts you should be ok but a voltmeter that you can keep an eye on would be best so you dont draw to much on the battery |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7618 Registered: Jul-06
| Posted on Wednesday, June 04, 2008 - 03:30 pm: |
If you've got the battery for it, sure. With a stock batttery probably not. www.odysseybatteries.com |
Post Number: 9406 Registered: Jun-04
| Posted on Wednesday, June 04, 2008 - 03:33 pm: |
"if you plan on playing it low and drawing 250 to 300 watts you should be ok but a voltmeter that you can keep an eye on would be best so you dont draw to much on the battery" my post was assuming your going to run a stock battery |
