Home > Message Board > Car Audio > Amplifiers > Archive through June 06, 2008 > I need a mtx amp someone please help me?
Author Thread: I need a mtx amp someone please help me?
Username: Slivdogg
St.ignace, Mi
United states
Post Number: 11
i want a good mtx amp for theses 2 subs... im going all mtx! can someone give me some suggestions?
http://sonicelectronix.com/item_2239_MTX+Audio+T7512-44.html
Username: Nd4spd18
Northwest PA
Post Number: 7614
I can give you a suggestion, don't buy an mtx amp. Or sub.
Username: Slivdogg
St.ignace, Mi
United states
Post Number: 13
why?
Username: Ctmike
Ct.
Post Number: 6219
because there's better that you can get for the same amount you'd spend on mtx.
Username: Slivdogg
St.ignace, Mi
United states
Post Number: 14
ok well should i get a kicker set then?
Username: Ctmike
Ct.
Post Number: 6222
are you dead set on buying from circuit city or something? what are you looking for in your system.
Username: Slivdogg
St.ignace, Mi
United states
Post Number: 15
ok this is what i want... i want a ststem you can hear from like a mile away...but yet at the same time sound great. rite now i have a chevy silverado and i dnt wanna buy a new alt. so i wanna be able to use what i have now without buying more stuff? and im thinking about 2 kicker cvx 12".... but id what amp to get...any suggestions? ill take any?
Username: Ctmike
Ct.
Post Number: 6224
the cvxs' are nice subs. not worth msrp, but if buying from online you can get them at a decent price. not sure on your alt. but those subs are going to want 1500w+ for the pair, so not sure if your charging system is up to handle that much. but if you can i'd personlly pick up a sundown saz1500d and run the pair at 1ohm (so make sure the subs are dual 4ohm vc).
Username: Slivdogg
St.ignace, Mi
United states
Post Number: 16
what amp should i get the mtx or hifonix?
http://sonicelectronix.com/item_5645_--+CRAZY+DEAL--+--+MTX+Audio+TA7801+Thunder +7801.html
http://sonicelectronix.com/item_12211_Hifonics+BXi+1608D.html
Username: Snowball123
West Allis, WI
United States
Post Number: 800
Username: Drant19
DUB-C, TX
Post Number: 1025
whats your budget for amp and subs?
Username: Slivdogg
St.ignace, Mi
United states
Post Number: 19
ok my decision is made im gettin 2 mtx 7500s with a mtx mono amp
Username: Drant19
DUB-C, TX
Post Number: 1026
if you were to go with just 1 brand...i would have picked differently than MTX.
MTX isnt that good IMO
Username: Slivdogg
St.ignace, Mi
United states
Post Number: 23
ok then what would u go with?
Username: Drant19
DUB-C, TX
Post Number: 1028
whats your budget?
Username: Slivdogg
St.ignace, Mi
United states
Post Number: 41
my budget is $600
Username: Mario_silva
COATZACOALCOS, VERACRUZ
MEXICO
Post Number: 9
http://www.ikesound.com/product-product_id/6624
Check this out...
MEXICO
Post Number: 10
And this...
http://www.ikesound.com/product-product_id/5551
MEXICO
Post Number: 11
i just foud this, very good deal for a good quality sub...
http://www.ikesound.com/product-product_id/7348
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5358
Why don't you talk to kevin holden, he can hook you up with some great stuffs and 600$ is a very decent amount.
IMO forget about MTX and get quality stuffs
Home > Message Board > Car Audio > Amplifiers > Archive through June 06, 2008 > I need a mtx amp someone please help me? [ « Previous ] [ Next » ]
