Thread: I think I became a victom... |
Gold Member Username: Rideredder
Cornell,
IL
Post Number: 1430 Registered: Sep-05
| Posted on Wednesday, June 04, 2008 - 05:07 am: |
of the Pioneer Preimer RCA problem. I haven't fully diagnosed the problem yet, but I think that's the problem. This all happened after I blew my sub awhile back. I unhooked everything after that and waited for the sub to get fixed. I went to hook it back up recently and I get very little sound from the sub(s). Only at max volume on the HU do I hear anything from the sub, and even then I could only faintly hear voice, no bass at all. I tried several different subs and got the same results. Anyone else think it's the HU, or could it be something else? HU is the Premier 780mp. I don't have another HU I can try at the moment to make sure, that's why I'm asking. |
Silver Member Username: Gibsonguy
Storrs,
CT
Post Number: 108 Registered: May-08
| Posted on Wednesday, June 04, 2008 - 06:20 am: |
did you try using a different source? I usually hook my mp3 player up to my subwoofer amp and if that fixes the problem then you know there is something wrong with your rca outputs on your hu. if the problem persists then it may not be the hu. thats just how i check. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7612 Registered: Jul-06
| Posted on Wednesday, June 04, 2008 - 09:07 am: |
I do the same thing, cnnect an mp3 player to the amp and see if it works. Since its a pioneer my bet would be on the HU. |
Gold Member Username: Safe_cracker
Chicago,
IL
US
Post Number: 4592 Registered: Jan-06
| Posted on Wednesday, June 04, 2008 - 09:39 am: |
MP3 ain't gonna tell you anything other than it isn't the amp. RCA thing is an easy fix. Polo. |
Chicago,
IL
US
Post Number: 4593 Registered: Jan-06
| Posted on Wednesday, June 04, 2008 - 09:45 am: |
http://forum.ecoustics.com/bbs/messages/4/488358.html |
Gold Member Username: Southernrebel
Monroe,
Louisiana
2 DD3515s, 2...
Post Number: 6419 Registered: Mar-04
| Posted on Wednesday, June 04, 2008 - 10:25 am: |
Make sure you have the RCA's in the right outputs on the HU. Check the crossover on the amp and make sure its at 60-120hz Low Pass. Also, try the sub RCA's in the 'Rear' output jacks. Set the HU's crossover to 'pass' (if it has a crossover setting). If that plays...you may have killed your sub outputs on the HU. |
Gold Member Username: Jkidder
Worlds gunna end,
In
2012
Post Number: 3595 Registered: Nov-05
| Posted on Wednesday, June 04, 2008 - 12:27 pm: |
what kind of preout voltage does an mp3 player put out though. wouldn't you have to change your gains and all that jazz? the cisco kid |
Northwest PA
Post Number: 7616 Registered: Jul-06
| Posted on Wednesday, June 04, 2008 - 01:07 pm: |
No, it will play. Probably not loud but it will play fine for testing. " MP3 ain't gonna tell you anything other than it isn't the amp. " No sh!t, thats the purpose of the test haha. To tell if it's the amp, or HU / RCA cables. |
Gold Member Username: 04redmach1
Columbus,
GA
Post Number: 2017 Registered: Mar-06
| Posted on Wednesday, June 04, 2008 - 01:45 pm: |
Yea, I don't deal with Pioneer period anymore. Too many issues. Eclipse FTW! Kevin |
Bronze Member Username: 4realadeala
Tampa,
Florida
Post Number: 45 Registered: Mar-08
| Posted on Wednesday, June 04, 2008 - 03:54 pm: |
My Pioneer DEH- 6400 had one side of the rear rca go out. On my monoblock I could not tell (I just thought I had a crap amp). So when I bought a two channel amp only one speaker would play. So I traded sides and then the other played. I am not sure what gave me the idea but I moved the preouts from the rear out to the front out, problem was solved. I have owned this hu since early 2001. |
Gold Member Username: Th3pwn3r
I compensate...
Post Number: 8183 Registered: Jul-06
| Posted on Wednesday, June 04, 2008 - 04:36 pm: |
This has been an issue with Pioneer HUs for years now. It's pretty sad IMO, I always steer people into other brands for head units because of it. |
Gold Member Username: Insearchofbass
Post Number: 9410 Registered: Jun-04
| Posted on Wednesday, June 04, 2008 - 04:47 pm: |
"This has been an issue with Pioneer HUs for years now. It's pretty sad IMO, I always steer people into other brands for head units because of it." I skipped buying a pioneer headunit because of it |
Chicago,
IL
US
Post Number: 4595 Registered: Jan-06
| Posted on Wednesday, June 04, 2008 - 04:57 pm: |
"This has been an issue with Pioneer HUs for years now. It's pretty sad IMO, I always steer people into other brands for head units because of it" It isn't pioneers fault! You should always make sure everything is correctly grounded amp, HU, etc including the HU chassis needs to be grounded which nobody does. They have a micro fuse inside the HU that blows if you do not do the following and this is to protect the preamp or the rest could go, not seen by other cheaper brands ^^^^. By the way hotswapping RCAs will do it to also not Pioneers fault lOl. I showed you twots how to fix it in the above link either learn, evolve or get the fck out of the hobby damn crybabies hahahhahha... BTW- You can also send it to me to fix.. Polo.
Silver Member Username: Dynamik
Post Number: 102 Registered: Feb-08
| Posted on Wednesday, June 04, 2008 - 05:04 pm: |
Hey, if it is the Pioneer, would you be willing to sell me the RCA Harness??? PWEEEEEASE??? lol |
Chicago,
IL
US
Post Number: 4599 Registered: Jan-06
| Posted on Wednesday, June 04, 2008 - 10:03 pm: |
"I think my HU became a victom..." What the subject should read ^ |
