Home > Message Board > Car Audio > Amplifiers > Archive through June 06, 2008 > Dead Amp
Author Thread: Dead Amp
Username: Moheevi
Post Number: 137
I forgot to take out the fuse on the power wire and it sparked when I inserted into amp...I think it killed it.
Username: Nd4spd18
Northwest PA
Post Number: 7610
Well does it work? A spark is normal when you make the connection the completes the cuircuit.......
and learn what youre doing before yo udo break something. You don't take the fuse out you disconnect the negative battery cable.
Username: Moheevi
Post Number: 138
alright...thanks for the feedback...I guess
Username: Naledge503
LowDownForum.com
Post Number: 3812
You guess? lol. How are we supposed to know if you killed it? We arent there.
Does the amp turn on and work? lol...
Username: Moheevi
Post Number: 139
No that's why I think it's dead. It won't turn on!
Home > Message Board > Car Audio > Amplifiers > Archive through June 06, 2008 > Dead Amp [ « Previous ] [ Next » ]
