Thread: Radio dieing with volume |
New member Username: 248vista
Post Number: 1 Registered: Jun-08
| Posted on Tuesday, June 03, 2008 - 10:04 pm: |
I have a Sony radio that when put at more than 20% of its volume capacity will reset itself (turn off) and turn itself back on and will continue to do this until the volume is lowered and the headunit is reset. Any ideas on what is causing this? |
Bronze Member Username: Neyetmare
Post Number: 26 Registered: Nov-07
| Posted on Tuesday, June 03, 2008 - 10:13 pm: |
i had this same problem with my stock deck, i never figured out the exact solution but im pretty sure it was just it overheating. |
Gold Member Username: Kpa2727
Old Bridge,
NJ
USA !
Post Number: 1330 Registered: May-07
| Posted on Tuesday, June 03, 2008 - 10:44 pm: |
usual cause of it is your over taxing the radio. the radio is working so hard to push your speakers it's ether heating up or clipping the signal so bad to your speakers it shuts off to prevent damage. most of sonys car audio products = crap. so if your driving large speakers thats why, or you have a bad ground to the radio. |
Post Number: 2 Registered: Jun-08
| Posted on Tuesday, June 03, 2008 - 11:18 pm: |
Keith, How would i be able to tell if the ground is bad? |
