Thread: CDT: CL vs HD series |
Bronze Member Username: Molaq
Waltham,
MA
Post Number: 26 Registered: Nov-04
| Posted on Tuesday, June 03, 2008 - 06:19 pm: |
I have had a set of CDT CL62 components in my ford explorer for several years now and have been very happy with them. I am inheriting my wife's Acura TL and want to upgrade the stock stuff. I am considering moving up to the CDT HD series. What does anybody think about this? Is it worth the price increase over the CL series? I am considering the CDT HD62 component set. Is it worth upgrading to the M6 mid? What about the DRT26 tweeter? FWIW, I am not planning on putting a sub in right now (or maybe ever). Appreciate any feedback. |
Gold Member Username: Drant19
DUB-C,
TX
Post Number: 1023 Registered: Aug-07
| Posted on Tuesday, June 03, 2008 - 06:53 pm: |
if your not planning on running a sub then upgrade to the M6 driver. and as far as the tweeters go, it just depends on if u want a mellow or harsher tweet. ask Exige Audio about better details.. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7606 Registered: Jul-06
| Posted on Tuesday, June 03, 2008 - 08:25 pm: |
If you're gonna upgrade, make it worth it and get the ES line. |
Silver Member Username: Exige
CDT, Audiopulse Dealer
Post Number: 406 Registered: Nov-07
| Posted on Wednesday, June 04, 2008 - 01:28 am: |
Jeffrey I'd be happy to help you out with CDT. Check your PM's. |
