Thread: Cheapest amp for 2 jl w3 v3's |
Silver Member Username: 2pacalypse1971
Sandusky,
Oh
Post Number: 498 Registered: Jul-05
| Posted on Tuesday, June 03, 2008 - 05:44 pm: |
liek the title says, they are single 2 ohm, 12 inches, i think they are rated at 300 rms i think, but i'm sure can take 400, i was thinking about the rockford t500/1, then others are talking bout the jl 500/1, are they're any other cheaper amps taht will supply me with about 700-800 rms at 1 ohm? |
Gold Member Username: Naledge503
Portland,
Or
Post Number: 3795 Registered: Jun-06
| Posted on Tuesday, June 03, 2008 - 07:33 pm: |
How much do you want to spend? |
Gold Member Username: Somedonniedude
Illinois
United States
Post Number: 1636 Registered: May-07
| Posted on Tuesday, June 03, 2008 - 08:16 pm: |
Look into DEI/Directed/Orion D1200. The Rockford should be a good choice too. With the power you want I would scratch the JL amp. |
Sandusky,
Oh
Post Number: 500 Registered: Jul-05
| Posted on Tuesday, June 03, 2008 - 08:38 pm: |
well do you guys think i'll be safe with giving the subs about 750-800 watts, i knwo it says they are 300 rms but do you think each on could take about 400, my budget is about 200 shipped, i'm still in the process of getting the subs off someone online so i'm not in that much of a hurry to ge tthe amp so i'm open to all suggestiong |
Gold Member Username: Insearchofbass
Post Number: 9407 Registered: Jun-04
| Posted on Wednesday, June 04, 2008 - 03:40 pm: |
you would be fine to buy a more powerfull amp and set the gain to 600 watts if you wanted and that would give you cleaner power...but even if you wanted to go with more power it doesnt look like they can take much more safely looking at jl's chart for them |
Sandusky,
Oh
Post Number: 501 Registered: Jul-05
| Posted on Wednesday, June 04, 2008 - 05:06 pm: |
do directed amps do they're rated power or are they overrated?? |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 5360 Registered: Dec-05
| Posted on Friday, June 06, 2008 - 07:48 am: |
they do rated power. |
