Thread: So is it bad... |
Bronze Member Username: Neyetmare
Post Number: 22 Registered: Nov-07
| Posted on Tuesday, June 03, 2008 - 04:54 pm: |
to run my deck on a constant power, even if i remove my faceplate? |
Gold Member Username: Kpa2727
Old Bridge,
NJ
USA !
Post Number: 1328 Registered: May-07
| Posted on Tuesday, June 03, 2008 - 05:16 pm: |
no but if your radio gets left on at all it will kill your battery otherwse not really it's bassiclly the same thing except it will drain your battery. |
Bronze Member Username: Jayhunter
New Haven,
IN
Post Number: 35 Registered: May-08
| Posted on Tuesday, June 03, 2008 - 05:23 pm: |
Why would you want your head unit to be on 14/7? Install a kill switch on the power cable for your battery's sake. |
Post Number: 25 Registered: Nov-07
| Posted on Tuesday, June 03, 2008 - 10:01 pm: |
i have three batteries. But i did have a kill switch for my amps power and my hu's power and it was reversed for some reason, so when my amp was on my hu was off. And the ignition wire on my harness was bad so it wasn't remotely turning my hu or my amp on when i started my car. |
New Haven,
IN
Post Number: 40 Registered: May-08
| Posted on Wednesday, June 04, 2008 - 12:46 pm: |
You may want to just overhaul your electrical system, sounds like a mess. |
