Thread: Mike - Jl 300 2v2 |
Gold Member Username: Mixmastaspig
Team RD,
Post Number: 1705 Registered: Sep-05
| Posted on Tuesday, June 03, 2008 - 02:59 pm: |
What are the specs on those amps as I might be interested in taking them off your hands! Any pics? Thanks |
Diamond Member Username: Bestmankind
Post Number: 21086 Registered: Oct-05
| Posted on Tuesday, June 03, 2008 - 03:01 pm: |
Rated Power (2 Channel Mode): 150 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V) Rated Power (Bridged Mono): 300 W RMS x 1 @ 3 ohm-8 ohm (11V-14.5V) THD at Rated Power: <0.03% @ 4 ohm per ch. S/N Ratio: >108.5 dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth) Frequency Response: 5 Hz - 30 kHz (+0, -1dB) Damping Factor: >200 @ 4 ohm per ch. / 50 Hz >100 @ 2 ohm per ch. / 50 Hz Slew Rate: ±25 V / µS @ 4 ohm per ch. Left to Right Channel Separation: >75 dB @ 1 kHz Input Range: Switchable from 200mV-2V RMS to 800mV-8V RMS Dimensions (L x W x H): 13.40 in. x 9.25 in. x 2.27 in. 340 mm x 235 mm x 58 mm |
Gold Member Username: Mike11202
RE MT 15 VFL 200.1 ,
Sewell, NJ
US
Post Number: 1748 Registered: Nov-06
| Posted on Tuesday, June 03, 2008 - 03:07 pm: |
I'm not selling the 300/2v2, just the sub, sub amp, and boxes. But if I have to it will be $300 shipped. ($399 brand new from dealer) Still has 1 year warranty left, bought from an authorized dealer and is still in perfect condition. 150 x 2 @1-4ohms Best sounding amp I've heard, it brings the comps to life. I switched from an ED Nine.2x (200 x 2) and what a difference. |
Post Number: 21087 Registered: Oct-05
| Posted on Tuesday, June 03, 2008 - 03:14 pm: |
yeah mike that amp is awesome. i used to have the 450/4 and the sq was awesome. btw mike, are you using the xover on the amp or on the hu. for me setting the amp at full range and using the xover on the hu sounded much better. |
Team RD,
Post Number: 1706 Registered: Sep-05
| Posted on Tuesday, June 03, 2008 - 03:40 pm: |
Ahh my bad, I read something in another post about the amp and $60 shipped each so I got them mixed up as I knew nothing about the JL amps...lol Been thinking about tossing another set or two of speakers in my car. Is it noticable or not reccomended to run 2 different 4 channel amps in a single set up? I currently have a 4 channel Helix Dark Blue amp and it's been great and I'm not sure if I can keep it and grab something else or if I should sell it and grab 2 new 4channel amps, like Sundown (Sax-100.4), RD (55.4) or Kicker (KX850.4 or 650.4) Thanks |
