Home > Message Board > Car Audio > Subwoofers > Archive through June 07, 2008 > The Big 3...Please Explain
Author Thread: The Big 3...Please Explain
Username: Audiosaab
Potomac, MD
Post Number: 162
I was just wondering what else i needed to upgrade to achive the so called "Big 3"
Ive already upped stock alternator from 90 amp to a 120 HO alternator...
And wiring is all the right size so im not sure what else there is....
thanks
Username: Mixmastaspig
Team RD, Canada
Post Number: 1703
The big 3 consists of:
Alternator to battery
Battery ground to Chasis
Engine to Chasis
Use all 0awg if you can
Username: Audiosaab
Potomac, MD
Post Number: 164
wait so the big 3 is only wiring? or do i need to upgrade my battery as well?
Team RD, Canada
Post Number: 1704
Yep the big 3 is just upgrading your wire under the hood.
http://www.the12volt.com/installbay/forum_posts.asp~TID~73496~PN~1
It's best to get a nice big battery up front and people reccomend a Deep Cycle battery. I went with a large starter battery up front and it's worked well for me but I have been thinking about grabbing a deep cycle too see if anything changes.
Username: Ninobrn99
Honolulu, HI
Post Number: 42
just wiring. what vehicle are you doing it on?
Username: Naledge503
Portland, Or
Post Number: 3785
It is one of the easiest, basic, best things you can do for your electrical. The wiring from the manufacturer is just to meet the minimum requirements. Even on a small system, the big 3 can make a noticeable difference.
Username: Audiosaab
Potomac, MD
Post Number: 165
alright great, and im doing it on a Saab 900 SE Turbo 1996.......web sites make it sound so much more complicated than it truly is lol
Username: Ninobrn99
Honolulu, HI
Post Number: 43
ah..i saw it was a 90amp and i know my jeep is.
Username: Gibsonguy
Storrs, CT
Post Number: 95
and just to make something very clear here that people sometimes get confused on.
You never replace wire when you do the big 3, you are always supposed to add onto existing wire. Remember people, more is better:-)
Username: Big_edge_head
Milwaukee, Wisconsin
Post Number: 2256
http://i128.photobucket.com/albums/p173/stavenmist/big3.jpg
Got the pic from killer.:-)
A pic is worth
1000 posts!!
Post Number: 16934
May be redundant but here's another good link for it.
http://www.s10forum.com/forum/f27/big-three-big-3-upgrade-how-to-321309/
Username: Audiosaab
Potomac, MD
Post Number: 168
great thanks people! :-) i get it now for sure....why dosent life has diagrams like that
Username: Tdeaton1021
Near Tampa, Florida
Post Number: 4475
http://blog.edesignaudio.com/?cat=5
There is a video for it....
Username: Andrew571
Stillwater/Edmond, Oklahoma
Post Number: 1877
I have two runs of 1/0 per each connection in the Big 3. Been working great since
Home > Message Board > Car Audio > Subwoofers > Archive through June 07, 2008 > The Big 3...Please Explain [ « Previous ] [ Next » ]
