Thread: Good DMM for the $$$ |
Gold Member Username: Somedonniedude
Illinois
United States
Post Number: 1634 Registered: May-07
| Posted on Tuesday, June 03, 2008 - 02:23 pm: |
What's a good one for around $20 or so. I'll buy anywhere so wherever you guys find one. If there is any reason to spend more let me know, Thanks. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7601 Registered: Jul-06
| Posted on Tuesday, June 03, 2008 - 02:49 pm: |
Any DMM that doesn't look cheap as crap will be just fine everything you need it for related to car audio. There is a reason to spend a little more though for a "true RMS" meter, which is needed for certain things. DMMs of that type are almost always decent quality also. Another feature to get if you're going for a good meter is autoranging, with manual range you have to know the range that the reading you will get will be in and manually set it on the meter. This is not necessary but nice to have. Personally I carry around a cheap meter from harbor freight b/c I use it so much it gets beat up, and then I have a good true RMS meter if I need it. One thing not to waste your money on is one with an so called built in scope. They are nothing like a real oscilloscope. |
Illinois
United States
Post Number: 1638 Registered: May-07
| Posted on Tuesday, June 03, 2008 - 08:33 pm: |
Alright thanks for the DL. My old one has a refresh rate of 2 per second (or whatever they call it) and would only go to 1/10 of a decimal place. I'll just find one on ebay that has a little better specs, since mine drove me crazy for some odd reason lol, not that it even matters much lol. |
Northwest PA
Post Number: 7609 Registered: Jul-06
| Posted on Tuesday, June 03, 2008 - 08:39 pm: |
It may have more percision in lower ranges as that is how it usually works. |
Platinum Member Username: Wingmanalive
A pic is worth
1000 posts!!
Post Number: 16931 Registered: Jun-06
| Posted on Tuesday, June 03, 2008 - 08:57 pm: |
"Personally I carry around a cheap meter from harbor freight b/c I use it so much it gets beat up, and then I have a good true RMS meter if I need it." Me too. Harbor freight is a great place for disposable tools. The innards of a DMM are quite simple so even the cheapest one are fairly accurate. |
Illinois
United States
Post Number: 1644 Registered: May-07
| Posted on Wednesday, June 04, 2008 - 12:27 pm: |
Paul do you have any DMM's for sale? |
A pic is worth
1000 posts!!
Post Number: 16946 Registered: Jun-06
| Posted on Wednesday, June 04, 2008 - 06:33 pm: |
Why lol? They're $5. Buy two. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92020 |
Silver Member Username: Waresgaragestereo
Fort Valley,
GA
Post Number: 193 Registered: Mar-08
| Posted on Wednesday, June 04, 2008 - 06:46 pm: |
hey m.s buddy whats up? havent heard from you in a while. anyway, sir, go to Advance Autoparts i bought one from them for like 50 bucks and its awesome! it reads everything under the sun. they have cheaper ones but i chose this one. it checks voltage ohms ignition systems sylonids, etc great deal! hope you find what ur looking for. |
Gold Member Username: Naledge503
LowDownForum.com
Post Number: 3819 Registered: Jun-06
| Posted on Wednesday, June 04, 2008 - 07:02 pm: |
I picked up a craftsman DMM at sears for $10. Does everything I need it to so far. They always have sales on them. My uncle screwed it up somehow and I took it back and they replaced it on the spot. |
A pic is worth
1000 posts!!
Post Number: 16958 Registered: Jun-06
| Posted on Wednesday, June 04, 2008 - 09:16 pm: |
Yeah they're really not that expensive an item. Even at $10. |
Illinois
United States
Post Number: 1647 Registered: May-07
| Posted on Wednesday, June 04, 2008 - 10:43 pm: |
I think my last DMM was the same one at harbor freight (except yellow), or atleast the same brand. The only time it made me really mad was in this one kids car, it would not pick up on his box terminals what so ever, made me look retarded lol. Well I'm going into sears tomorrow since I have some tools to exchange so I'll pick one up there. Thanks for the help guys. |
Northwest PA
Post Number: 7622 Registered: Jul-06
| Posted on Thursday, June 05, 2008 - 08:17 am: |
Pick up a craftsman one with True RMS, autoranging, etc and that will last ya forever. |
