Home > Message Board > Car Audio > Amplifiers > Archive through June 06, 2008 > MTX Audio TA5601 Thunder 5601
Author Thread: MTX Audio TA5601 Thunder 5601
Username: Slivdogg
St.ignace, Mi
United states
Post Number: 8
can someone send me a link for a good amp kit for this amp?
Username: Waresgaragestereo
Fort Valley, GA
Post Number: 187
what amp?
Username: Slivdogg
St.ignace, Mi
United states
Post Number: 9
HERES A LINK TO THE AMP
http://sonicelectronix.com/item_3777_--+CRAZY+DEAL--+--+MTX+Audio+TA5601+Thunder +5601.html
Fort Valley, GA
Post Number: 188
heres a link to the kit i'd use
http://sonicelectronix.com/item_52_Complete+4+Gauge+Amplifier+Kit.html
my setup uses 4ga wire from bat to back of the van the has a distribution block from 4ga to 8ga then it runs into the amps.
Username: Insearchofbass
Post Number: 9408
good amp....my bro owns one of those amps....id skip that amp kit listed above and go with a Kicker PK4 4 Gauge amp kit as a first pick or a KnuKonceptz 4 guage amp kit if it fits your amp as a second lesser quality choice....but make sure you have the right size fuse on your power wire which should match the total fuse size of your amp or amps on that power wire....if you need a different fuse size than your amp kit gives you can order or buy one of the same type that matches the fuse rating you need
Username: Slivdogg
St.ignace, Mi
United states
Post Number: 24
ok im gettin a mtx amp and subs
Home > Message Board > Car Audio > Amplifiers > Archive through June 06, 2008 > MTX Audio TA5601 Thunder 5601 [ « Previous ] [ Next » ]
