Thread: Headunit wiring harness |
New member Username: Palewhiteboy
BC
Post Number: 6 Registered: May-08
| Posted on Monday, June 02, 2008 - 08:58 pm: |
i just got a new head unit for my car and the guy at the store said i would need to buy a second wiring harness to plug it into my factory wiring harness.is this true? he also said installing it would be difficult but i dunno if hes just trying to get me to pay for their 65$ installation fee. |
Gold Member Username: Kpa2727
Old Bridge,
NJ
USA !
Post Number: 1327 Registered: May-07
| Posted on Tuesday, June 03, 2008 - 05:14 pm: |
no headunits tough unless it has heater controls and air conditioner. u can do it as long as you feel confident enough to do some wiring. an adapter is the easiest way to go it will allow you to just plug your radio in and no wiring needed. it's like 15 or less the one you will prob be easiest to find is a harness made by a company called metra. |
BC
Post Number: 7 Registered: May-08
| Posted on Wednesday, June 04, 2008 - 10:47 pm: |
yeah i got an adapter and wired it all up and got a metra dash kit as well. installed without a hitch. thanks for the info. |
Old Bridge,
NJ
USA !
Post Number: 1335 Registered: May-07
| Posted on Thursday, June 05, 2008 - 01:12 am: |
no problem. |
