Thread: AQ1200D problems with clipping/gain set. |
Gold Member Username: Somedonniedude
Illinois
United States
Post Number: 1624 Registered: May-07
| Posted on Sunday, June 01, 2008 - 08:54 pm: |
So after having my AQ1200D installed for a few weeks and trying everything I can think of, I am stumped! Well first off, I'll start with gain issues. When I was setting my gain and turned my SSF up, my voltage went up, even when playing tones that were higher and nowhere close to the SSF alignment. it shouldn't even effect that.Is there something I don't understand because I fell retarded asking this. Also, my amp remote has a clip light. When cranked (music in general, not the remote or gain), the higher frequency's clip and low freq's don't and there is a noticeable gap between (gonna say 35hz vs 50hz). What I mean by that is, the lows/35hz don't come to life until the highs are just unbearable. Second, when my sub is unhooked and I crank the gain, why does the clip light go on? Wouldn't there have to be a load on the amp before the amp could be technically "pushed into clipping"? I've went through my HU and checked everything could affect my amps signal. I even disconnected it to completley reset it. My head unit is a Pioneer DEH-P 3500 if it makes any difference. If anyone can make sense out what I'm saying, please gimme some input. My only other thought of correcting this would be to invest in a crossover. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7585 Registered: Jul-06
| Posted on Monday, June 02, 2008 - 10:57 am: |
Set your SSF a little below the tuning of your box and don't worry about that anymore. Then do this. Do the procedure to set the gain properly with the DMM, but try using a few different frequencies i.e. 40 hz, 50 hz, 60 hz or similar. You should get the same reading with each. If you get different readings, somethings wrong with the input signal, probably the HU is doing something to the signal to make it not flat. |
Illinois
United States
Post Number: 1626 Registered: May-07
| Posted on Monday, June 02, 2008 - 02:11 pm: |
At different freq it is different, the lower the tone the lower the voltage. My DMM broke a few days ago, it was a cheap one my uncle picked up (flea market quality). So All I can do is use my clip light on my remote as a source of measure. |
Northwest PA
Post Number: 7595 Registered: Jul-06
| Posted on Tuesday, June 03, 2008 - 10:36 am: |
Then ya need to get a new one, can't troubleshoot much of anything without it. If the readings are in fact different then the input signal is pissed up. Something on the HU has to be altering it. EQ, loudness, bass boost, everything has to be off or zeroed. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 5361 Registered: Dec-05
| Posted on Friday, June 06, 2008 - 07:51 am: |
maybe your dmm was cr4ppy and didn't do the job properly |
Northwest PA
Post Number: 7632 Registered: Jul-06
| Posted on Friday, June 06, 2008 - 08:15 am: |
Highly doubtful. What you're hearing, no lows, and what you measuredm lower frequencey = lower voltage, are consistent. Something wrong with the signal going to the amp. Unless you've got an EQ, crossover, etc it has to be the HU. Check the settings for a HPF setting. |
Illinois
United States
Post Number: 1659 Registered: May-07
| Posted on Friday, June 06, 2008 - 11:20 am: |
The only setting I have on is my HPF for my speakers, and it cuts them out around 80hz (has settings for 50, 80, & 125hz). It has a (+) and (-) adjustment but I left it flat at 0. The SLA shouldn't mess with anything should it, I'm under the impression that it equally rises the output of the HU? I was going to go get a DMM yesterday, But before I left my whole town lost power so I couldn't get any money from the bank.  |
Northwest PA
Post Number: 7640 Registered: Jul-06
| Posted on Friday, June 06, 2008 - 11:30 am: |
What HU do you have and whats SLA? |
Illinois
United States
Post Number: 1660 Registered: May-07
| Posted on Friday, June 06, 2008 - 06:39 pm: |
Pioneer DEH-P 3500 SLA stands for Signal Level Adjustment (I think?) It seems to adjust the HU output as a whole, like an overall volume control that you "set and forget" type of thing. |
Silver Member Username: Snowball123
West Allis,
WI
United States
Post Number: 833 Registered: Oct-07
| Posted on Friday, June 06, 2008 - 09:32 pm: |
are you talking about slave? because then yeah leave that at 0. |
Illinois
United States
Post Number: 1673 Registered: May-07
| Posted on Monday, June 09, 2008 - 04:49 pm: |
My HU doesn't have a slave option. OK, so today I messed with it some more. Well I think I completely hate this amp so far... I don't know where to start. 1. I got the voltage up on the 30hz region, but now it's higher that the 50hz area. By adjusting the gain it did some odd things. 2. I set my SSF to around 28hz, but the sub still moves like a mofo on 18hz. Make any sense? Not to me, 18hz should be non-existent. 3. I don't think my HU has anything to do with this, but it has a retardedly sensitive volume... between the HU being on 54 and 55, there was a 4volt spike in amp output. Kinda retarded I'd say. I am so sick of my whole setup. I want to get a new sub and HU so bad, but I hate giving of on something that seems like it's suck a simple fix, but it's just plain retarded. Bought a sheet of MDF today for my next box, them I'm gonna see if I can put everything in one of my friends car (amp and sub) and see if everything is still retarded. I never had these problems with my last setup, so it must be the amp  |
Illinois
United States
Post Number: 1700 Registered: May-07
| Posted on Thursday, June 12, 2008 - 01:38 am: |
So I have came to the conclusion that either these amps suck, or mine is defective. I think I'm gonna send an email to AQ and ask if any of these problems make sense. Something like turning the SSF filter up SHOULD NOT indicate an increase in voltage anywhere in the frequency range of an amp. If anything the voltage should drop as the SSF is turned up (once it reaches that certain freq). Anyone think there is something I am doing wrong? |
Silver Member Username: Kaerfpl
Spencerport,
NY
Post Number: 919 Registered: Jun-06
| Posted on Sunday, June 15, 2008 - 04:10 am: |
Ive been beating my AQ1200 since I got it and haven't had a problem yet! I'd contact AQ ASAP to see if they know something about your problem. |
