Thread: Box for 12" type r |
Silver Member Username: Dirtrider125
Post Number: 202 Registered: Apr-07
| Posted on Sunday, June 01, 2008 - 01:52 am: |
2.0 cubic feet tuned to 36hz is this good? |
Silver Member Username: Phil_salisbury
Post Number: 673 Registered: Sep-06
| Posted on Sunday, June 01, 2008 - 02:16 am: |
Yes, give it herds of power and your ear's will bleed. |
Post Number: 204 Registered: Apr-07
| Posted on Sunday, June 01, 2008 - 06:20 am: |
really with just 1 |
Post Number: 205 Registered: Apr-07
| Posted on Sunday, June 01, 2008 - 06:21 am: |
will that be louder than 2 12" kicker cvrs in a factory made ported box |
Post Number: 206 Registered: Apr-07
| Posted on Sunday, June 01, 2008 - 06:26 am: |
Platinum Member Username: James1115
Use a simple...
Post Number: 10626 Registered: Dec-04
| Posted on Sunday, June 01, 2008 - 10:06 am: |
it will have better sq, as far as being louder I doubt it but you never know. |
Platinum Member Username: Rovin
1 15 = 149.1DBs Trinidad & T...
Post Number: 13842 Registered: Jul-05
| Posted on Sunday, June 01, 2008 - 12:04 pm: |
tune a bit lower like 32\33\34hz if u want more sq from it .... |
Gold Member Username: Kpa2727
Old Bridge,
NJ
USA !
Post Number: 1321 Registered: May-07
| Posted on Sunday, June 01, 2008 - 04:30 pm: |
for just mine i have 34 hz with 2 cubes ported and it pounds really loud but i'm drooling for a set of jake papas revo or tc sounds. ahhh when i get money i can see myself spending many hours on a new install. |
Post Number: 207 Registered: Apr-07
| Posted on Sunday, June 01, 2008 - 04:49 pm: |
so u got just 1? with a hifonics 1606d on just the 1? |
Old Bridge,
NJ
USA !
Post Number: 1325 Registered: May-07
| Posted on Sunday, June 01, 2008 - 11:09 pm: |
yea but i go easy on it. http://www.youtube.com/v/5-9EdrzHANs&hl |
Post Number: 215 Registered: Apr-07
| Posted on Monday, June 02, 2008 - 01:27 pm: |
what is the difference between using slot port and port tubes? which is better |
Diamond Member Username: Bestmankind
Post Number: 21044 Registered: Oct-05
| Posted on Monday, June 02, 2008 - 01:49 pm: |
listen to rovin. he is the resident type r specialist. |
Post Number: 13849 Registered: Jul-05
| Posted on Monday, June 02, 2008 - 03:21 pm: |
^^^aah but u were a type R owner too - ur 1st 'real' sub ..... |
Post Number: 21046 Registered: Oct-05
| Posted on Monday, June 02, 2008 - 03:35 pm: |
true. brings back memories. i wouldn't mind running a pair of type rs again. |
Post Number: 216 Registered: Apr-07
| Posted on Monday, June 02, 2008 - 04:41 pm: |
ok so whats better slot port or port tube rovin? |
Post Number: 13852 Registered: Jul-05
| Posted on Monday, June 02, 2008 - 10:10 pm: |
they will sound good in anybox type use aeroports to save on space or if space is no issue do slot - i like em both but tune low to enjoy those loooooows ... |
