Thread: Budget system |
Silver Member Username: Rds2oo8
MN
Post Number: 245 Registered: Nov-06
| Posted on Sunday, June 01, 2008 - 12:32 am: |
for about $800 looking for sq type system 2 12s or 1 15 amp box wiring head unit all included throw out some ideas plz |
Silver Member Username: Howtoeatapencil
Post Number: 125 Registered: Mar-08
| Posted on Sunday, June 01, 2008 - 12:40 am: |
Ask kevin holden, im sure he can find something nice for you |
Gold Member Username: Ctmike
Ct.
Post Number: 6183 Registered: Feb-06
| Posted on Sunday, June 01, 2008 - 12:41 am: |
not that big of a budget for everything. you could buy my 15" aa atlas for cheap to start with very nice sq sub that doesn't need alot of power. |
New member Username: Ggs08
GA
Post Number: 2 Registered: May-08
| Posted on Sunday, June 01, 2008 - 01:02 am: |
Sub $188 http://cgi.ebay.com/NEW-RE-AUDIO-SE15D4-15-1200w-COMPETITION-CAR-SUBWOOFER_W0QQi temZ280231795782QQihZ018QQcategoryZ18804QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Amp $200 http://cgi.ebay.com/NEW-KICKER-ZX750-1-MONO-CLASS-D-AMPLIFIER-06ZX750-1_W0QQitem Z180247137361QQihZ008QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Amp kit $46 http://cgi.ebay.com/PHOENIX-GOLD-AKIT42-4-GAUGE-COMPLETE-CAR-AMP-WIRING-KIT_W0QQ itemZ360055852354QQihZ023QQcategoryZ71528QQssPageNameZWDVWQQrdZ1QQcmdZViewItem HU $150 http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=6197 and you could build your own box for about $40 which would put just over $600 |
Silver Member Username: Hurricanebr1an
Western Burbs of Chicago,
IL
Usa
Post Number: 551 Registered: Sep-07
| Posted on Sunday, June 01, 2008 - 10:06 am: |
15" FI Q Dual 1 ohm $280ish Kicker zx750.1 refurbished $200ish Fishercustoms box $150ish 4 Ga amp kit $50ish $120 left for a H/U...pioneer or alpine And Robert quick note of advice if you want good SQ make sure you lay some sound deadener. |
Gold Member Username: Insearchofbass
Post Number: 9336 Registered: Jun-04
| Posted on Sunday, June 01, 2008 - 10:11 am: |
Im not sure id recommend a pioneer headunit unless they have worked out the rca grounding issue |
Platinum Member Username: James1115
Use a simple...
Post Number: 10627 Registered: Dec-04
| Posted on Sunday, June 01, 2008 - 10:13 am: |
I would buy Mike's atlas to start and build from there. Can you build your own box? 2.5 sealed would be perfect for it, ask Mike louden if he still has the box that I built for my avalanche and see if he will sell it to you cheap. Get a 300 watt amp at 4 ohms and a cheap cd player for $200 or so on ebay(look alpine) then grab a 4 guage amp kit for like $50. You don't need a 4 guage amp kit with only 300 watts but I would do it anyways because you will prob upgrade in the future and you dont want to have to rewire. |
IL
Usa
Post Number: 552 Registered: Sep-07
| Posted on Monday, June 02, 2008 - 09:42 am: |
"Im not sure id recommend a pioneer headunit unless they have worked out the rca grounding issue" didnt even know there was a problem |
Silver Member Username: Waresgaragestereo
Fort Valley,
GA
Post Number: 185 Registered: Mar-08
| Posted on Monday, June 02, 2008 - 09:49 am: |
yeah pioneer sux bad. i have a pioneer hu that was given to me. i cant use with my system cuz it keeps cutting off on low notes. i bought a JVC from my brother and its awesome! nop pioneer radios or amps. idk about their speakers |
Gold Member Username: 04redmach1
Columbus,
GA
Post Number: 1998 Registered: Mar-06
| Posted on Monday, June 02, 2008 - 11:52 am: |
I do have something that would work for you, and leave enough money to either build your own box, or have one built. Would include an Eclipse headunit Shoot me an email. Kevin lowhz01@yahoo.com |
Silver Member Username: Snowball123
West Allis,
WI
United States
Post Number: 779 Registered: Oct-07
| Posted on Monday, June 02, 2008 - 05:21 pm: |
get premier not pioneer. |
Gold Member Username: Big_edge_head
Milwaukee,
Wisconsin
Post Number: 2247 Registered: Mar-07
| Posted on Monday, June 02, 2008 - 05:24 pm: |
It's the same thing.^^^^ |
West Allis,
WI
United States
Post Number: 780 Registered: Oct-07
| Posted on Monday, June 02, 2008 - 06:20 pm: |
well id rather have premier than pioneer. havent had problems with mine. |
Gold Member Username: Drant19
DUB-C,
TX
Post Number: 1016 Registered: Aug-07
| Posted on Monday, June 02, 2008 - 06:39 pm: |
i have a premier 780mp and had the rca grounding problem. i wont buy another pioneer/premier again. ALPINE HUs! |
