Thread: Arc Audi KAR 265? Any good? Just got a set for free |
New member Username: Jasonli18t
Post Number: 1 Registered: May-08
| Posted on Saturday, May 31, 2008 - 06:24 pm: |
New member here...the slow moving car audio forum on VWVortex has led me here, looks like a great community. I just got a set of these 6.5 inch Arc Audio components for free. I have a 2005 VW GTI with the monsoon audio system. My plan is to leave the stock headunit, and put these components in the stock locations for the woofer and tweeter to maintaing an OEM look. I have an old rockford punch 600.4 4 channel ampt hat I found buried in my closet which I will use to power these. I have a few questions. Is this component set any good? Based on my limited investigation, they are a budget set of speakers, but people seem to really like them in this price range. My amp can provide 75 wattx rms x 2 or 150 wattx rsx x 2 when bridged. These speakers are rated for 50 watts RMS but some say they can handle more. How should I wire them to the amp? I purchase this converter: http://enfigcarstereo.com/shopsite_sc/store/html/METRA_74_90003.html it was a bit pricey but i hope it will make the install easier and provide better sound quality then a cheap, non OEM converter. Thanks in advance for any and all help and input. |
Silver Member Username: Exige
Cincinnati
Post Number: 366 Registered: Nov-07
| Posted on Saturday, May 31, 2008 - 10:32 pm: |
I haven't had any listening time with those Arc components, but Arc is a solid company overall. If it's got their name on it, I would expect them to be decent. Your will be fine for those...no need to bridge. Make sure to fully deaden your doors with sound deadener and seal everything up the best you can. Experiment with tweeter placement. Though the stock locations may be convenient, other spots might sound better. Use a piece of velcro to mount it temporarily at different points before you decide on a final spot. Good luck! |
Cincinnati
Post Number: 367 Registered: Nov-07
| Posted on Saturday, May 31, 2008 - 10:33 pm: |
Sry i meant to say "Your amp will be fine for those...no need to bridge it." |
Post Number: 2 Registered: May-08
| Posted on Sunday, June 01, 2008 - 05:05 pm: |
thanks for the reply. so far I have not heard anything negative about these speakers or this company so thats a plus. I should be installing everything this week once my line out converter gets here. |
Post Number: 3 Registered: May-08
| Posted on Tuesday, June 03, 2008 - 08:26 pm: |
anyone else? |
