Home > Message Board > Car Audio > Amplifiers > Archive through June 06, 2008 > Bigger Fuse??
Author Thread: Bigger Fuse??
Username: Spads8
Post Number: 9
i was just thinking if my amp has a 25amp fuse could i put a 30amp in it to get more performance out of it
Username: Bonhamd
TC, MI
Post Number: 696
no
Username: Spads8
Post Number: 11
so it'll still be the same as the 25 amp fuse
Username: Imalik
15 SI Mag9.1=Boom, New Jersey
Jerzee Playa
Post Number: 600
Only use what is recommended for the amp, you are only asking for trouble with the bigger fuse
Username: Nd4spd18
Northwest PA
Post Number: 7570
NEVER replace a fuse with a bigger one, that defeats the entire purpose of the fuse being there.
Username: N2audio
Lawrence, Ks
Post Number: 1583
You'd get 2 things -
a higher likelyhood of amp damage if, for some reason you had a current surge at the amp.
Higher likelyhood of fire.
Home > Message Board > Car Audio > Amplifiers > Archive through June 06, 2008 > Bigger Fuse?? [ « Previous ] [ Next » ]
