Thread: HO Alternator for 93 Legend? |
New member Username: Iimasta_pii
Riverside,
CA
Post Number: 6 Registered: May-08
| Posted on Thursday, May 29, 2008 - 04:05 am: |
I.ve been looking for quite some time now, and I recently found out from a mechanic that 1993 Acura Legends can't handle a High Output Alternator. Does anybody know otherwise? It's really bugging me because I want to get a Rockford Fosgate T1500bd, and that beastly amp definitely requires and HO alt. Can anybody help me out? Ive done my research and concluded that theres no hope for a HO alt. in my Legend, but if somebody knows maybe another way, please ket me know! Thanks, Pat |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7558 Registered: Jul-06
| Posted on Thursday, May 29, 2008 - 02:52 pm: |
" found out from a mechanic " First mistake....... most of them know absolutely nothing about electrical systems beyond what their training teaches them (a lot of which is wrong BTW), such as what you just mentioned. Contact first www.motorcityreman.com If they can't help you then try www.ohiogen.com They usually can build an HO alt for almost any car but it will cost you big. |
Riverside,
CA
Post Number: 7 Registered: May-08
| Posted on Thursday, May 29, 2008 - 05:20 pm: |
Sorry then let me reword that. I went to see a mechanic, and he called the local alternator shop and thats what they said |
Northwest PA
Post Number: 7568 Registered: Jul-06
| Posted on Friday, May 30, 2008 - 10:31 am: |
Same deal. THEY don't have one doesn't mean nobody does. |
Riverside,
CA
Post Number: 8 Registered: May-08
| Posted on Friday, May 30, 2008 - 03:37 pm: |
Alright thanks, I called Ohio Gen and they can get me like a 210 amp one for a little over $500! cant afford it right now, but hopefully in the future. Thanks! |
Northwest PA
Post Number: 7582 Registered: Jul-06
| Posted on Monday, June 02, 2008 - 10:41 am: |
For an import car thats actually not THAT bad. Did MCR not have anything b/c theirs are good and cost less. |
Bronze Member Username: Levelzero
Post Number: 40 Registered: Aug-07
| Posted on Monday, June 02, 2008 - 12:22 pm: |
Have you tried asking the folks over on http://www.acura-legend.com/vbulletin/ Post under Acura Legend/2nd Generation. Before doing so, you may want to search the forum in case the question was brought up previously. |
Northwest PA
Post Number: 7591 Registered: Jul-06
| Posted on Monday, June 02, 2008 - 02:09 pm: |
Beware theres a lot of people on car forums who don't know jack about electronics. Another warning, avoid iraggi and excessive amperage....... they have been known to have bad customer service and alt problems respectively. |
