Thread: Volt meter |
Silver Member Username: Howtoeatapencil
Post Number: 121 Registered: Mar-08
| Posted on Thursday, May 29, 2008 - 02:28 am: |
where can i get a cheap voltmeter to stick near me while i drive so i can watch my voltage.doesn't need to be beautiful or mounted nicely, just work |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7557 Registered: Jul-06
| Posted on Thursday, May 29, 2008 - 02:46 pm: |
http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/1333957/vpcsid/0 /SFV/30046 I have installed a few of those and they work fairly well. |
Gold Member Username: Th3pwn3r
I compensate...
Post Number: 8147 Registered: Jul-06
| Posted on Sunday, June 01, 2008 - 11:30 am: |
Make sure to use a digital multi meter to check for variance between the meter and actual power. Remember, there's resistance through the wire. |
Post Number: 126 Registered: Mar-08
| Posted on Sunday, June 01, 2008 - 08:22 pm: |
"check for variance between the meter and actual power" What do you mean by the actual power? |
Platinum Member Username: Wingmanalive
A pic is worth
1000 posts!!
Post Number: 16903 Registered: Jun-06
| Posted on Sunday, June 01, 2008 - 09:28 pm: |
He means to use a DMM to check the accuracy of the meter. Even less than expensive DMM's are more accurate that volt meters. I know my volt meter on my solar battery bank can have a reading variance of +/- .5v from that of my DMM reading of the same bank. |
