Home > Message Board > Car Audio > Subwoofers > Archive through June 07, 2008 > Battery WIRING HELP PLEASE!
Author Thread: Battery WIRING HELP PLEASE!
Username: Deadrabit
Post Number: 396
i really really need to know if i have to wire the negitive from the starter battery to the 2nd battery or not! i am going to start install on friday!!
can i take my neg on the 2nd battery to a ground some place close in the car or do i need to run 2 wires to the starter battery????
Username: Nd4spd18
Northwest PA
Post Number: 7574
Nothing goes to the starter, where the hell did you get that from.
It would be ideal to run a ground wire from front battery - to rear battery - just like you do with the positive. (assuming the batteries are the same otherwise you have to isolate them)
IF and only IF you have done the big 3 (which you should have) it is possible to ground the rear battery to the vehicle. But if it's not a unibody car, it has to be to the frame not the body.
Username: Deadrabit
Post Number: 399
i have not done the big 3 because i don't have a bigger alt yet.
i think i found my wiring problem
i didn't mean starter. i was talking about the starter battery. the 1st battery.
hope my stock alt will hold up with both of these batteries....
if not then ill have to buy a new one
u guys don't have to tell me that i need a bigger alt because i know i do.
its a 90 amp alt powering 1600rms
but i don't have the other amp in yet so it will be alright for now
Username: •cam•
BC
Post Number: 2521
Just don't ground to both the battery and the chassis.
A pic is worth
1000 posts!!
Post Number: 16837
"u guys don't have to tell me that i need a bigger alt because i know i do.
its a 90 amp alt powering 1600rms"
Ok we won't, but you do.
Username: Nd4spd18
Northwest PA
Post Number: 7592
If you have not done the big 3, do NOT ground that 2nd battery to the chassis
Home > Message Board > Car Audio > Subwoofers > Archive through June 07, 2008 > Battery WIRING HELP PLEASE! [ « Previous ] [ Next » ]
