Home > Message Board > Car Audio > Amplifiers > Archive through June 06, 2008 > Biggest amp this car can handle?
Author Thread: Biggest amp this car can handle?
Username: Vivi2000
Post Number: 30
Im getting a 2001 cavalier LS soon, and want to put a system in it. Everything is stock and i dont want to put a HO Alt in it. What is the biggest amp I could run on this. I believe it has a 105A alternator in it right now.
Username: 04redmach1
Columbus, GA
Post Number: 1990
You can run a good 1000-1200 rms without an issue and not upgrade anything.
Kevin
Username: 420alldaylong
Post Number: 3636
Install very important
Username: Waresgaragestereo
Fort Valley, GA
Post Number: 177
Like Kevin said and like i would say a good 1000-1200rms without upgradeing.
Ho alts and big 3 upgrade get expensive fast.
Username: Hurricanebr1an
Western Burbs of Chicago, IL
Usa
Post Number: 550
I wouldnt run over 1000wrms.
Is it the original alternator?
Username: Somedonniedude
Illinois
United States
Post Number: 1606
If you have no other aftermarket electricals running, you should be ok on 1200w, but no more.
Username: Vivi2000
Post Number: 31
Everything is original, No upgrades have been done to the car in terms of electrical. I dont plan on running over 1000rms right now anyways.
Username: Nd4spd18
Northwest PA
Post Number: 7565
1000w is even pushing it but it should be ok. I've installed in several vehicles that that same size GM alt.
Username: Vivi2000
Post Number: 32
Somewhere around 600wrms should be fine with no upgrades and just running the correct gauge wire right. Also what gauge wire would I need? I plan to put the amp underneath the front passenger seat If I can. And if it wont fit I would need to place it in the trunk, what size should I get then?
Illinois
United States
Post Number: 1615
4 gauge will work. You can always buy bigger wire if you plan on upgrading in the future, but with 4ga you still have a good amount of headroom.
What are you using this amp for?
If you need wire hit up a Paul Larrea, he is a great guy with great prices and should have most of what you need.
Home > Message Board > Car Audio > Amplifiers > Archive through June 06, 2008 > Biggest amp this car can handle? [ « Previous ] [ Next » ]
