Thread: Where to put "Great Stuff" |
Bronze Member Username: Jayhunter
New Haven,
IN
Post Number: 27 Registered: May-08
| Posted on Wednesday, May 28, 2008 - 04:32 pm: |
Already put weather stripping for doors on my license plate to reduce some rattling. Went out and bought a can of Great Stuff and I'm not entirely sure where I should apply it in my trunk. Where do you suggest putting it at? |
Platinum Member Username: Wingmanalive
A pic is worth
1000 posts!!
Post Number: 16815 Registered: Jun-06
| Posted on Wednesday, May 28, 2008 - 09:53 pm: |
Careful here using that. That stuff is very hard to remove if and when you intend to. If you inject it into body cavities consider it permanent. Have you considered E-dead or some other sound deadening product? Self stick. |
New Haven,
IN
Post Number: 28 Registered: May-08
| Posted on Wednesday, May 28, 2008 - 10:52 pm: |
Well, I am probably going to be the last person ever to drive my car considering it is a 95' and it's over 100K so I'm not too worried about it being ucky for the next driver. I thought about buying some dynomat but I hear Great Stuff works pretty well too(plus it is much cheaper). |
A pic is worth
1000 posts!!
Post Number: 16827 Registered: Jun-06
| Posted on Thursday, May 29, 2008 - 08:27 pm: |
Messy but cheap. What's nice is its' expanding qualities. Plus once dry you can shave it to any form. |
Silver Member Username: Howtoeatapencil
Post Number: 122 Registered: Mar-08
| Posted on Thursday, May 29, 2008 - 09:06 pm: |
where did u pick this stuff up at? and how much was it? |
A pic is worth
1000 posts!!
Post Number: 16832 Registered: Jun-06
| Posted on Thursday, May 29, 2008 - 09:12 pm: |
Any local hardware store. Lowes, the Depot, even Walmart has it. Like $8 or so per can. http://greatstuff.dow.com/greatstuff/diy/retail.htm |
New Haven,
IN
Post Number: 30 Registered: May-08
| Posted on Thursday, May 29, 2008 - 10:09 pm: |
I actually picked it up at Wallmart and it was only $4.25 after tax! So just sort of spray it around the trunk lid then? I probably won't need too much of it I assume. |
A pic is worth
1000 posts!!
Post Number: 16844 Registered: Jun-06
| Posted on Friday, May 30, 2008 - 10:23 pm: |
Apply it between the frames of the trunk. Get it as deep as you can and fill the cavities. It will look ugly but will do the job. |
