Thread: How to add a battery in the trunk? |
Silver Member Username: Howtoeatapencil
Post Number: 116 Registered: Mar-08
| Posted on Wednesday, May 28, 2008 - 01:23 pm: |
I have 1/0 gauge wire running from my battery to my amplifier, can i just add another battery in the trunk inline with the 1/0 gauge wire running to the amplifier and then ground the new battery to the chasis? Can i use 4 gauge wire for the battery ground, or do i need 1/0 gauge wire for that? |
Relevant Product Info
Silver Member Username: Prozack52
Cincinnati,
2-D615D4 Dia...
Post Number: 341 Registered: Feb-08
| Posted on Wednesday, May 28, 2008 - 01:50 pm: |
yeah add another fuse before battery then after battery then hook into amp and might as well stay 1/0 guage for ground man |
Post Number: 117 Registered: Mar-08
| Posted on Wednesday, May 28, 2008 - 04:23 pm: |
i only have enough 0 gauge for power and ground to my amp, and it would be a pain to buy like 3 or 4 more feet of it. is the 0 gauge nexesary or will 4 gauge work? |
Gold Member Username: Kpa2727
Old Bridge,
NJ
USA !
Post Number: 1305 Registered: May-07
| Posted on Wednesday, May 28, 2008 - 08:14 pm: |
NO 4 GUAGE just ask paul laurel on here for some he should be able to hook u up with the wire and a nice deal. don't skimp out you should keep it all same guage. |
Platinum Member Username: Wingmanalive
A pic is worth
1000 posts!!
Post Number: 16804 Registered: Jun-06
| Posted on Wednesday, May 28, 2008 - 08:36 pm: |
If you would've known any of this ahead of time I could've supplied the extra 1/0ga that you might need. At the very least I have several 3' 2ga with terminal already attached. Bummer. |
Gold Member Username: Frkkevin
Team DLS SuperNatural...
Post Number: 5169 Registered: Nov-05
| Posted on Wednesday, May 28, 2008 - 08:50 pm: |
if not just go to a local shop and buy a couple feet.. thats probably the most common thing i end up driving over to the local shop for lol |
Post Number: 119 Registered: Mar-08
| Posted on Wednesday, May 28, 2008 - 10:03 pm: |
hmm, ill probably be ordering some more stuff from paul soon haha |
Post Number: 120 Registered: Mar-08
| Posted on Thursday, May 29, 2008 - 01:39 am: |
what if i double up on the 4 gauge? |
Silver Member Username: Deadrabit
Post Number: 397 Registered: Jun-07
| Posted on Thursday, May 29, 2008 - 10:34 am: |
i guess u could double it up. i have some extra 0 guage ill sell u a few feet if u need it |
