Thread: Visonik V4000XD amp? |
Bronze Member Username: 71_chevelle
Post Number: 35 Registered: May-08
| Posted on Tuesday, May 27, 2008 - 01:32 pm: |
Is Visonik V4000XD Mono Block Amplifier a good amp? or am i just waisting my time with it? |
Relevant Product Info
Gold Member Username: Southernrebel
Monroe,
Louisiana
2 DD3515s, 2...
Post Number: 6400 Registered: Mar-04
| Posted on Tuesday, May 27, 2008 - 01:57 pm: |
IIRC, its a pretty strong amp. Same amp as the MA Audio HK4000. I see them at shows from time to time. Cheap raw power...~3200w @ 2ohm. As far as longevity, not sure. |
Diamond Member Username: Bestmankind
Post Number: 20928 Registered: Oct-05
| Posted on Tuesday, May 27, 2008 - 01:59 pm: |
not bad for a cheap amp i must say. btw what is "IIRC"? |
Gold Member Username: Loudon
Post Number: 2449 Registered: Jun-04
| Posted on Tuesday, May 27, 2008 - 02:03 pm: |
if i remember correctly a friend used one ... worked well for burps .. but daily it smooked .. blown fets and power supply lol .. on a solid 14v electrical ... if ur daily driving with it .. i say no.. burps- i say yes |
Post Number: 36 Registered: May-08
| Posted on Tuesday, May 27, 2008 - 03:48 pm: |
ok thank you thats what i was looking for. so would you say HIFONICS BRUTUS BXi2008D would be a good amp then? it has a more recognizable name |
Silver Member Username: Bonhamd
TC,
MI
Post Number: 661 Registered: Nov-07
| Posted on Tuesday, May 27, 2008 - 03:55 pm: |
what is your budget? The AQ2200D for $389 is a pretty good deal http://www.audioque.com/aq/AQamps2200D.htm |
Post Number: 37 Registered: May-08
| Posted on Tuesday, May 27, 2008 - 04:03 pm: |
hmmm i was thinkin around $300 do you know of any amps that'll push 2000 watts rms around $300? |
Gold Member Username: Jakeyplaysbass
St. Louis,
MO / ASU
Post Number: 2744 Registered: Jul-05
| Posted on Tuesday, May 27, 2008 - 04:39 pm: |
On a stock electrical you wont be seeing anywhere close to 2000rms for under 300 bucks. Unless you upgrade your alternator, big 3, and starter battery dont go above 1000-1200rms. |
Post Number: 38 Registered: May-08
| Posted on Tuesday, May 27, 2008 - 05:00 pm: |
yes i am going to upgrade the alt and the big 3 and the starter batt. so then do you know of any amps that are around $300 that push 2000 watts rms? |
St. Louis,
MO / ASU
Post Number: 2745 Registered: Jul-05
| Posted on Tuesday, May 27, 2008 - 06:20 pm: |
Used AQ2200d or try and find 2 used ED NINe.1s and strap them. |
Post Number: 39 Registered: May-08
| Posted on Tuesday, May 27, 2008 - 06:30 pm: |
ok i'll do that! thank you very much jake! |
