Thread: Grounding help |
Bronze Member Username: 4realadeala
Tampa,
Florida
Post Number: 40 Registered: Mar-08
| Posted on Monday, May 26, 2008 - 08:21 pm: |
If I wanted to add an amp for my highs and I placed it in the middle of my car, what should I look for to ground it to. Would any bolt connected to the frame work? It is a Honda Accord 4 door |
Platinum Member Username: Wingmanalive
A pic is worth
1000 posts!!
Post Number: 16787 Registered: Jun-06
| Posted on Monday, May 26, 2008 - 10:45 pm: |
Any steel frame member would do. |
Bronze Member Username: Jayhunter
New Haven,
IN
Post Number: 24 Registered: May-08
| Posted on Tuesday, May 27, 2008 - 07:09 pm: |
I have a civic and I grounded it right in my trunk, really man anywhere should work, just sand down the paint a lil. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 5347 Registered: Dec-05
| Posted on Tuesday, May 27, 2008 - 08:53 pm: |
trunk is a good place... i think you can also find a good ground by removing your back seat. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7560 Registered: Jul-06
| Posted on Thursday, May 29, 2008 - 03:17 pm: |
Seat bolts should work for that car. Front or back. |
Tampa,
Florida
Post Number: 41 Registered: Mar-08
| Posted on Thursday, May 29, 2008 - 07:00 pm: |
Thank you fellas |
