Home > Message Board > Car Audio > Head Units > Archive through August 01, 2008 > VCD Converter Pro 2.985
Author Thread: VCD Converter Pro 2.985
Username: Frostaldington
VCD Manager Pro is easy to use and powerful for experts as well. It enables you to convert and burn any VCD video file directly to VCD, DVD, SVCD, MPEG1 and MPEG2 format. Pro version included all the features of the lite version. In addition, it has embedded "DVD Author Express" and "DVD/VCD/SVCD Burner Engine". So it becomes an all-in-one VCD/SVCD/DVD Creator. And this program has been optimized for 64-bit CPU including Intel EM64T and AMD64. The video conversion speed is faster than most of our competitors. Now you can get this All-in-One video converter at a very competitive price! Support burning VCD/DVD/SVCD. Embedded "DVD author Express" is inside. Optimized for 64-bit CPU including Intel EM64T and AMD64. Convert avi to VCD/DVD/SVCD compatible mpeg file Support .VOB, .asf, .wmv, .rm, .rmvb, .mov format as input file Support DivX, XviD avi format Support MPEG1, MPEG2, MPEG4 video format Support MPEG layer1, layer2, layer3 audio format
Download Now
Home > Message Board > Car Audio > Head Units > Archive through August 01, 2008 > VCD Converter Pro 2.985 [ « Previous ] [ Next » ]
