Thread: Accuracy |
New member Username: Palewhiteboy
BC
Post Number: 3 Registered: May-08
| Posted on Sunday, May 25, 2008 - 09:25 pm: |
they say that ported and bandpass boxes arent as "accurate" as sealed but do they mean accurate as in the note of the bass or the timing of the note being played? |
Relevant Product Info
Silver Member Username: Dirtrider125
Post Number: 167 Registered: Apr-07
| Posted on Sunday, May 25, 2008 - 09:44 pm: |
they dont sound as clean but they louder |
BC
Post Number: 5 Registered: May-08
| Posted on Sunday, May 25, 2008 - 09:53 pm: |
would a sealed still belt out pounding lows without being ridiculously large? |
Gold Member Username: Tejcurrent
Post Number: 1363 Registered: Apr-07
| Posted on Sunday, May 25, 2008 - 10:32 pm: |
Still depends on vehicle, enclosure, sub(s) and power. |
Gold Member Username: Naledge503
Portland,
Or
Post Number: 3683 Registered: Jun-06
| Posted on Monday, May 26, 2008 - 04:18 pm: |
A ported enclosure when built properly can sound as good as a sealed enclosure. When I speak in terms of accuracy, it is the timing of the note or how precise the sub is playing the note without hesitating, or missing it. |
Gold Member Username: Cblaze
Rock island,
Tenesssee
Us
Post Number: 2101 Registered: Sep-07
| Posted on Monday, May 26, 2008 - 05:00 pm: |
its how well the enclosure is designed/built.the so called boomy sound from ported boxes is cuz of prefab ported boxes if ya want my opinion |
Gold Member Username: Skibum12189
Cleveland
Post Number: 2893 Registered: Mar-06
| Posted on Monday, May 26, 2008 - 08:03 pm: |
with my current sub, i went ported (my first ported setup) and i love it. the sub is probably a step up from the others i've owned, but it's just as clean as any other. my buddy's ported w7 is the same. both are clean and loud. ive never heard my current sub sealed, but it always seemed to me that the my previous subs always sounded as if they couldn't breath sealed. build a smaller ported box (to specs) and you should be able to maintain a nice balance of sq and spl |
