Thread: Problem ): |
Silver Member Username: Dubmc23
Rapid City,
SD
Post Number: 255 Registered: Sep-07
| Posted on Sunday, May 25, 2008 - 08:01 pm: |
ok heres the deal... i have a pioneer deh-p780mp hooked up to through the aux to my ipod...but it wont let me select the aux source to play my ipod...can any one help?? |
Relevant Product Info
Gold Member Username: The_image_dynamic
San Diego, California
Post Number: 3977 Registered: Dec-06
| Posted on Sunday, May 25, 2008 - 08:29 pm: |
You don't have the auxiliary setting switched to on. Use the multi-control to scroll to aux 1 and then push the multi-control to turn the function on. THEN select aux with the source button. I haven't changed any settings on mine in awhile but I think I remember the power has to be off too? |
Gold Member Username: Big_edge_head
Milwaukee,
Wisconsin
Post Number: 2207 Registered: Mar-07
| Posted on Sunday, May 25, 2008 - 09:05 pm: |
Yea, I think you have to turn the HU off first. Then press and hold the multi control in. |
Gold Member Username: Dakangofkrunk16
Boca Raton,
Florida
Post Number: 1651 Registered: May-07
| Posted on Sunday, May 25, 2008 - 09:10 pm: |
yea there right u have to go into demo mode or soemthing i had to do it on my Pioneer hu and then u'll see Aux off hit to on and voila |
Milwaukee,
Wisconsin
Post Number: 2208 Registered: Mar-07
| Posted on Sunday, May 25, 2008 - 09:31 pm: |
I'm 99% sure. Just turn it off, hold in multi control, and scroll through until it says "AUX" and turn it on. |
Gold Member Username: Naledge503
Portland,
Or
Post Number: 3675 Registered: Jun-06
| Posted on Sunday, May 25, 2008 - 10:20 pm: |
Do you know if you can do it this way with the deh-p480mp? Or do I need the CD-IB100II? There is an aux input in the back of the H/U. |
Milwaukee,
Wisconsin
Post Number: 2209 Registered: Mar-07
| Posted on Sunday, May 25, 2008 - 10:38 pm: |
If theres an aux input then you should be able to. I'm guessing its the same as my old pioneer 3800 where you just turn it off, hold the volume button in until a menu pops up, and scroll for aux and turn it on. I'm not sure though... |
Portland,
Or
Post Number: 3676 Registered: Jun-06
| Posted on Sunday, May 25, 2008 - 10:53 pm: |
I got it. I dont know why I didnt try before. Hold source until the H/U turns off. Hold source again and the clock will pop up. Next press function until AUX pops up and turn it on. |
