Home > Message Board > Car Audio > Amplifiers > Archive through June 06, 2008 > Type R install help
Author Thread: Type R install help
Username: Speckto
so i have a used type r 12" dual 4 ohm and just bought a alpine mrp-m850 ... I was anxious so i set it up without the sub in a box... I put pos to pos on speaker and neg to neg and then the sub came with a real small wire that connects a different pos to a different neg both on the sub... in the end the sub ended up bouncing hard but in the front seat i couldnt even tell i had a sub hooked up...
Is this because
a) no box
b) bad wire setup
c) bad sub (bought it from a friend and made the mistake of never listening to it first)
Username: Dirtrider125
Post Number: 166
probly cuz u dont got it in a box but if u want another one let me know cuz im sellin mine to get 2 15s
Username: Speckto
so you think its wired correctly??
Home > Message Board > Car Audio > Amplifiers > Archive through June 06, 2008 > Type R install help [ « Previous ] [ Next » ]
