Home > Message Board > Car Audio > Head Units > Archive through August 01, 2008 > Dual head unit no sound
Author Thread: Dual head unit no sound
Username: Crazyt
im hooking up a dual cd7700 somethin or other in a 2000 sunfire, turns on,cd plays but no sound...wtf??? need help with this quick!!
Username: Jayhunter
Post Number: 9
Might want to get a new wiring harness, I had some problems with the one that came with mine. You sure you hooked everthing up right? I mean it's getting power just sounds like your speaker wires might be loose on the plug of the harness.
Username: Crazyt
99% sure its hooked up right, i'll double check all the connections, most likely that i need another harness though,thanks
Username: Kpa2727
Old Bridge, NJ
USA !
Post Number: 1282
i'm surprised you got power, gm cars like the sunfire ::i installed a pioneer on:: same year and all. they require a external power feed if u use a metra kit you have to wire your own other then that not much else you could have wrong.
Username: Crazyt
i have the power wire run to the fuse box,so the power isnt a problem.I was told i may be missing a wire,or may have to run one myself...any idea which one that would cause this problem? 2 days now tryin to figure this out with no luck
Home > Message Board > Car Audio > Head Units > Archive through August 01, 2008 > Dual head unit no sound [ « Previous ] [ Next » ]
