Thread: To risky? |
Silver Member Username: Howtoeatapencil
Post Number: 104 Registered: Mar-08
| Posted on Saturday, May 24, 2008 - 02:32 am: |
Ample Audio EX 300DX 1500 @ 1ohm RD alpha 12" 0 gauge power and ground 70 amp alternator Can i run this stuff at 1000 watts? No other amplifiers in my system. Do i risk voltage drops that could damage my amplifier? Extra battery in the trunk will have what effect? |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 5345 Registered: Dec-05
| Posted on Saturday, May 24, 2008 - 09:05 am: |
i'd look a HO alt. |
Post Number: 105 Registered: Mar-08
| Posted on Saturday, May 24, 2008 - 01:47 pm: |
I know that a HO alternator would solve my problems, but would it be possible to run it at this without one? |
Post Number: 106 Registered: Mar-08
| Posted on Saturday, May 24, 2008 - 11:53 pm: |
bump |
Gold Member Username: Ctmike
Ct.
Post Number: 6152 Registered: Feb-06
| Posted on Saturday, May 24, 2008 - 11:57 pm: |
get the ho alt. |
Gold Member Username: Somedonniedude
Illinois
United States
Post Number: 1585 Registered: May-07
| Posted on Sunday, May 25, 2008 - 04:57 pm: |
I think 1000w would still put too much of a strain on that alternator, and yes that will cause voltage drops that WILL hurt your amp. In your case there is no way around a HO alt (unless you like spending way more money than needed). |
Post Number: 107 Registered: Mar-08
| Posted on Sunday, May 25, 2008 - 09:31 pm: |
what about running it at 500 watts continuous and pushing it up to 1000 watts for short intervals? like 1 minute or less, just to show off |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1579 Registered: Mar-04
| Posted on Tuesday, May 27, 2008 - 11:00 am: |
I'd hook it up and monitor your voltage. It's not like the amp will draw 100A continuously - not even close. If you're sagging to 12 or lower you'll know you need to reduce the gain and go easy on the volume until you can get your HO alt. If you maintain at least 12, and get around 13 most of the time you should be fine. |
Post Number: 5349 Registered: Dec-05
| Posted on Tuesday, May 27, 2008 - 08:57 pm: |
can youtell us your car model? is it an import, domestic etc? |
Post Number: 115 Registered: Mar-08
| Posted on Tuesday, May 27, 2008 - 11:04 pm: |
i ave a 97 toyota corolla..optidriven, i think ill do that..so around 13 volts should be fine? |
Lawrence,
Ks
Post Number: 1580 Registered: Mar-04
| Posted on Wednesday, May 28, 2008 - 11:00 am: |
Your car's voltage fluctuates a lot, and there's a lot of gray area around when is the right time to go with a HO alt. You're always better safe than sorry, but at the same time, why spend the money if there's really no reason to. A healthy battery should rest at around 12.5v, for it to charge you need to see 13v+ most (90%?) of the time. I used to run 1100w with a 75A alt. At idle I'd see around 12-12.4v, but at any RPM above 1.5k or so I had 13.6-13.8v. Obviously it's not ideal to run like that (with the sags to ~12), but as long as your alt will charge the battery you won't end up stranded on the side of the road. However - having that much stress on the alt will most likely shorten its life. The 75A alt I had died after 2 years in that state - then again, it had 226k on it. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 7562 Registered: Jul-06
| Posted on Thursday, May 29, 2008 - 03:24 pm: |
I'd say that amount of power is too much for that alt. |
Post Number: 124 Registered: Mar-08
| Posted on Friday, May 30, 2008 - 02:30 am: |
I think i will hook it up and get a voltmeter so i can watch it while im driving, and just listen to it around 500-750 watts, and just crank it up to 1000-1200 for short periods. Should i be alright? Would that extra deep cycle battery help me out if i wanted to run it with not a whole lot of power, then push it up everyonce and a while for those short bursts? |
