Thread: Need some expert help |
New member Username: Kennym
Austin,
Tx
Usa
Post Number: 1 Registered: May-08
| Posted on Saturday, May 24, 2008 - 12:34 am: |
I have a system in my mountainer right now and its 2 12 in type s's. I have a memphis class ab/ class d hybrid 55w x 4/ 400wx1 amp, memphis 5x7 pr 15-pr572 speakers and a alpine cda 9886 deck. I want to get 2 type r 12's and keep the amp i have powering my speakers still. What would be the best amp for my two new subs (would an alpine pdx-4.100 work?) and even better question is this even possible to do? |
Bronze Member Username: Type94
Kitchener ,
Ontario
Post Number: 54 Registered: May-08
| Posted on Saturday, May 24, 2008 - 02:04 am: |
No , alpine amps are not build for power , there for mild listeners , go with a soundstream amp or a hifonics BXi 1206D amp and power the subs at 1 ohm . Thats my 2 cents |
Gold Member Username: Ctmike
Ct.
Post Number: 6140 Registered: Feb-06
| Posted on Saturday, May 24, 2008 - 08:18 am: |
DON'T LISTEN TO FRAZ!! STUPID INFO GIVEN^^. and fraz, if you can't give decent imput, then don't post anything at all. but to the op, you'll want a mono amp for the subs. if going alpine, i'd suggest either a pdx1000.1 for the pair, or a pdx600.1 (one for each sub). |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 5344 Registered: Dec-05
| Posted on Saturday, May 24, 2008 - 09:00 am: |
i agree. |
Austin,
Tx
Usa
Post Number: 2 Registered: May-08
| Posted on Saturday, May 24, 2008 - 10:46 am: |
Ok thanks guys |
Kitchener ,
Ontario
Post Number: 55 Registered: May-08
| Posted on Saturday, May 24, 2008 - 04:02 pm: |
LMFAOOO |
Ct.
Post Number: 6144 Registered: Feb-06
| Posted on Saturday, May 24, 2008 - 04:44 pm: |
"LMFAOOO" ? |
Kitchener ,
Ontario
Post Number: 56 Registered: May-08
| Posted on Saturday, May 24, 2008 - 06:05 pm: |
I think i should make another thread lol |
Austin,
Tx
Usa
Post Number: 3 Registered: May-08
| Posted on Saturday, May 24, 2008 - 07:09 pm: |
so an alpine mpr-m1000 would get the job done? |
Ct.
Post Number: 6150 Registered: Feb-06
| Posted on Saturday, May 24, 2008 - 07:16 pm: |
if it does 1000wrms at the ohm load you need it will. you could give them even more if wanted to. |
