Home > Message Board > Car Audio > Amplifiers > Archive through June 06, 2008 > How should I wire my 800 watt @ 4 ohm...
Author Thread: How should I wire my 800 watt @ 4 ohm mono amp to my Kicker 12 inch CVR dual voice coil sub
Username: Brigr88
Anyone with the correct knowledge know what i should do.. Ive hooked up systems before but i never paid attention to those details and im putting one in my car and want to do it right... Any help?
Username: Bonhamd
TC, MI
Post Number: 635
dual 2 ohm or dual 4 ohm?
http://www.the12volt.com/caraudio/woofer_configurations.asp
Username: Somedonniedude
Illinois
United States
Post Number: 1573
and what amp do you have?
Username: Brigr88
Audiobahn 8001 mono channel amp and the sub is dual 2 ohm voice coils
Illinois
United States
Post Number: 1583
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=22
Wire it to 1 ohm/ option 1
I would take some precaution as 800w might be a little much for that sub.
Home > Message Board > Car Audio > Amplifiers > Archive through June 06, 2008 > How should I wire my 800 watt @ 4 ohm... [ « Previous ] [ Next » ]
