Thread: Controlling bass on hu |
Bronze Member Username: Dupe112309
Post Number: 88 Registered: Feb-08
| Posted on Wednesday, May 21, 2008 - 09:13 pm: |
hey just wondering what you think about controlling bass on your head unit. i have an alpine cda 9884. 2 type r's powered by zx1000.1 and type x components and type r coaxials powered by zx350.4....i had the sw level to +15 and bass set at 0. however my speakers were still flexing a little and one of my friends told me to put my bass down to -7, goes from -7 to +7. since they're powered by my amp should i just turn up the frequency? i can tell that my subs are being quieted bc the bass is turned to -7. What do you think? |
Gold Member Username: Kpa2727
Old Bridge,
NJ
USA !
Post Number: 1258 Registered: May-07
| Posted on Thursday, May 22, 2008 - 01:14 am: |
u should have a bass hz setting which should be at 80 hz. then a high pass filter you can turn on for the speakers, which should be around 120 hz. you also gotta understand a bass level refers to just that a bass level nothin else. if it's the same setting i'm thinking of it shouldn't affect your speakers only a highpass should effect that. |
Post Number: 89 Registered: Feb-08
| Posted on Thursday, May 22, 2008 - 08:17 am: |
i have the settings pretty close to that on my amplifiers, but im wondering about the head unit. if i have the frequencies set like that on the amplifier, will it matter what i have my bass set on my head unit? |
Old Bridge,
NJ
USA !
Post Number: 1265 Registered: May-07
| Posted on Thursday, May 22, 2008 - 02:43 pm: |
yes it will help to match the frequencies from the hu to the amp and you should hear the difference. |
Post Number: 90 Registered: Feb-08
| Posted on Thursday, May 22, 2008 - 04:10 pm: |
the thing is i dont have a "frequency setting" on my head unit. i have: sw level (0 to 15) bass level (-7 to 7) treble (-7 to 7) fader/balance. if i have sw set to 15, and everything else at 0, then have my speaker amp blocking all the low frequencies, it shouldnt matter right? |
Old Bridge,
NJ
USA !
Post Number: 1269 Registered: May-07
| Posted on Friday, May 23, 2008 - 12:01 pm: |
in that case typically not the freuency setting i'm refering to though is if you turn on the high pass filter on the headunit assuming if you have one. |
Post Number: 91 Registered: Feb-08
| Posted on Friday, May 23, 2008 - 02:49 pm: |
i'll look for it. what will the hpf do? |
Old Bridge,
NJ
USA !
Post Number: 1276 Registered: May-07
| Posted on Saturday, May 24, 2008 - 01:30 am: |
remove bass from your speakers do you don't over tax them at high volume. |
Post Number: 92 Registered: Feb-08
| Posted on Sunday, May 25, 2008 - 09:38 pm: |
so i can't turn the hpf on....but if i just adjust the frequency on the amp and put it all the way up to 200 would that be okay? |
