Home > Message Board > Car Audio > Subwoofers > Archive through May 25, 2008 > Electrial WOES
Author Thread: Electrial WOES
Username: Killerzracing71
Post Number: 2190
RF T1000BD 150 AMp fuse
RF 450.4 60 amp fuse
1 15" LCD for my car pc (power inverted AC input)
2 7" lcds for rear passanger
2 3: LCds
power invertor to charge my laptop for my PC
Possibly a Backup camera
WHat should i do i havent run the system yet to see V drop yet as i only have the RF 450.4 hooked up
110 alt in a 92 caprice 305 what yall think
Relevant Product Info
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5902
i think your alt will get owned
Username: 04redmach1
Columbus, GA
Post Number: 1956
I was thinking the same thing.
Kevin
Username: Insearchofbass
Post Number: 9262
well first of all I had a mtx 81000d 1500 rms that required a 150 amp fuse on a car with a 100-105 amp alternator and a optima red top battery under the hood and that alone was enough to pull to hard on the electrical so running that other stuff is just going to make things worse...I had about the same total amperage draw with all three amps running as your two amps and at 4000 rpm driving down the road system cranked pretty good and my headlights dimmed a good amount driving down the road...with just the mtx 81000d running during the day and none of my other amps on some music my car would almost die out running at idle...and I didnt have any screens or laptops hooked up in any of my situations I described...now you have a good idea what will happen if you try to run all that
I had all my amps on toggle switches so I could turn them on and off in case your wondering
Post Number: 2191
LOL thinks sean
Kevin, Reece still F wit yall but damn i wanted a answer im sure i needed a upgrade LMAO but how big an upgradw will i need
The 15" LCD, Laptop and System will be on the most
(not like thats helping any LOL)
Username: Big_edge_head
Milwaukee, Wisconsin
Post Number: 2193
sup killer:-)
Post Number: 2192
Hey hey hey
Home > Message Board > Car Audio > Subwoofers > Archive through May 25, 2008 > Electrial WOES [ « Previous ] [ Next » ]
