Home > Message Board > Car Audio > Subwoofers > Archive through May 19, 2008 > Advice please (ASAP)
Author Thread: Advice please (ASAP)
Username: Letstalksound
Hey I need help designing a box.
it's for
2 Treo ssi 12" subs (SSi12.22)
all the specs needed are here (i believe)
http://www.treoonline.com/infosheets/ssi_subwoofers.pdf
I would like the box vented much like Seth Walker's post on this page with each sub to have it's own port
http://forum.ecoustics.com/bbs/messages/4/222350.html
I'm not sure what frequency would be best to tune it to, any suggestions would be great...
listen to a mix of rap and rock, but use the sub more for rap looking for SQL (35 Hz??)
space in truck, max box size is:
15.5 x 36 x 30(HxWxD)inches.
this is the biggest box size possible, if it can be tunned correctly with a smaller depth or something that would be great.
wanna use 3/4 inch mdf
and do I need to double up the front so it's stronger, (2 (3/4) pieces stuck together)
if you need any more info let me know
thanks in advance
Username: Surferdude9371
Im BTL Bumpin
Post Number: 930
best thing to do is get in contact with phil at woodlawn cabinetry or BJ at fisher cutstoms they both design boxes and build them doing a great job
Home > Message Board > Car Audio > Subwoofers > Archive through May 19, 2008 > Advice please (ASAP) [ « Previous ] [ Next » ]
