Home > Message Board > Car Audio > Subwoofers > Archive through May 19, 2008 > Diagnosing Problem (cal payne)
Author Thread: Diagnosing Problem (cal payne)
Username: Skibum12189
Cleveland
Post Number: 2851
Alright, i've got the dmm, what voltages should the wire read at all spots with the car on.
i know my power should read ~14v and what not, but if you could, write down where the voltages should all roughly be (remote from HU, remote at the amp, ground, rca's....)
thanks alot, i thought i had it fixed today but then it stopped working again...
for those who don't know, my amps and eq stopped turning on, so i figured that it was the low remote voltage, so i hooked up a relay and it worked temporarily, but then stopped again and i'm stumped.
Cleveland
Post Number: 2855
bump
also, when i did get it to work (after it conked out the first time) the highs would cut out when i cranked it up decently loud...
before it stopped working the first time, i had absolutely zero problems, no cutting out or anything...
Username: Drant19
DUB-C, TX
Post Number: 959
when my comps kept cuttin out, it sounded like popping, it was because the xover was in the door and kept grounding.
just throwin that out there lol
Cleveland
Post Number: 2856
thank you, but that's not it
Cleveland
Post Number: 2857
bump
Username: •cam•
BC
Post Number: 2508
Everything you listed should read around 14 volts but the RCAs. Those carry musical signals.
Cleveland
Post Number: 2858
i thought the rca's did read some kind of voltage? but cool, ill check everything
Home > Message Board > Car Audio > Subwoofers > Archive through May 19, 2008 > Diagnosing Problem (cal payne) [ « Previous ] [ Next » ]
