Home > Message Board > Car Audio > Subwoofers > Archive through May 19, 2008 > Subs
Author Thread: Subs
Username: Clawless
Shreveport, La
I have a 2007 4 door silverado and tryn to figure how many jl w7 will fit with takn the seat out? and should i go with 10s or 12s?
Username: Hurricanebr1an
Western Burbs of Chicago, IL
Usa
Post Number: 533
You are going to take both back seats out?
Username: Surferdude9371
Im BTL Bumpin
Post Number: 919
you can get at least 4 12s in there with no back seats
Username: Clawless
Shreveport, La
what im tryn to do is to leave the back rest and take out the seat itself where i can build a box, but not too tall so i can still make a seat out of the box, i am going to have to go with a sealed box that way though.so what subs do you reccomend? how many?
Username: Jkidder
Worlds gunna end, In
2012
Post Number: 3554
do you already have an amp? whats your budget for subs and amp(s)? whats the overall goal of your system(what music do you listen to, competing at all, ground pounder)?
the cisco kid
Username: Clawless
Shreveport, La
i was thinking w7s or L7s. dont know on the amps.if i go with 4 12w7s then ill probably go with 4 jl 1000X1s. i listen to mostly rap. the goal of my sysyem is sound clarity and blowing the windows out. what do you reccomend? money is tight, but im building piece by piece.
Username: Drant19
DUB-C, TX
Post Number: 958
"money is tight"
and your thinking about "4 12w7s then ill probably go with 4 jl 1000X1s" maybe you should go with a different company other than JL if your money is so tight.
whats you budget?
Username: Nyyfan13
15 Mag
Post Number: 9629
"the goal of my sysyem is sound clarity and blowing the windows out"
Well, don't mean to burst your bubble but one of those goals is impossible....
Username: Clawless
Shreveport, La
Money is tight, but i have four thousand saved for this system. I know thats not even half, but in the next month i will have a total of ten thousand. Then im gettn close. Id rather sound clarity then blown windows out. What i need to know is if JL is the best way to go for the system im tryn to build?
Username: Insearchofbass
Post Number: 9239
"Money is tight, but i have four thousand saved for this system. I know thats not even half, but in the next month i will have a total of ten thousand. Then im gettn close. Id rather sound clarity then blown windows out. What i need to know is if JL is the best way to go for the system im tryn to build?"
4 grand is alot of money in my opinion and id have a hard time parting with that for car audio but to each his own
Username: Hittin1
LakeCharles LA., La
Post Number: 310
there are better Sql subs than the 12w7's.. You are gonna need elecrtical upgrades. 4 SURE! you shouldn't need 10K to comlete a bad azz system.. even starting from scratch..(unless you just wanna blow money on high priced... and IMO overpriced... equipment. a little reasearch and a few more posts.. you could come close to or even finish a great sounding, hard-hitting system.
Username: Loc_out
SOCAL
2 RE 15 XXX
Post Number: 2096
If your goal is sql you wont need 4 12's. Just do 2 12w7.
Username: Clawless
Shreveport, La
ok? well what to you reccomend if im just tryn to get sql?
Home > Message Board > Car Audio > Subwoofers > Archive through May 19, 2008 > Subs [ « Previous ] [ Next » ]
