Home > Message Board > Car Audio > Amplifiers > Archive through June 06, 2008 > Looking for an amp
Author Thread: Looking for an amp
Username: Dannyboyy
O/S Power!!!!, i lo...
Post Number: 498
looking for an amp to produce 1500-2000wrms @ .5 or 2 ohms. and has to be kinda cheep as far as amps go, but im open for all ideas i can always save up, thanks
Username: Nd4spd18
Northwest PA
Post Number: 7512
Well that kind of power at that impedance is not going to be cheap.
For 2 ohm, Kicker ZX1500.1 will do the job. For .5 ohm Sundown SAZ-1500d would be good.
Username: Drant19
DUB-C, TX
Post Number: 956
^^^if you have the charging upgrades for those amps, if you dont have a HO alt, i wouldnt run that sundown at .5 ohm
Username: Nd4spd18
Northwest PA
Post Number: 7516
^^^^ Indeed I wouldn't run either of those amps without it
Username: 04redmach1
Columbus, GA
Post Number: 1933
To run those amps, I would for sure set back a good $1000 for electrical upgrades. Running at .5 ohm will kill the efficiency and you will have even more of a power hog on your hands.
Kevin
Home > Message Board > Car Audio > Amplifiers > Archive through June 06, 2008 > Looking for an amp [ « Previous ] [ Next » ]
