Home > Message Board > Car Audio > Subwoofers > Archive through May 19, 2008 > Alpine Type R Wiring
Author Thread: Alpine Type R Wiring
Username: Audiosaab
Potomac, MD
Post Number: 135
Hey,
So i, at this very moment, am wiring my subwoofers to my box because i belive i did it incorrectly before...
I am wiring the subwoofers at 1 ohm and they are Alpine Type R 4ohm DVC 12" ers
I wanted to know if anyone has experience with these subwoofers, and if so could you tell me where to place the bannana clips on them, because i can either place them in the holes at the top of each "press" down thing on the 2 + and 2 - areas where u place the wire due to the fact that they fit in there....
or... i could be placing them in the + and - terminal themselves with the + and - wiring from the box but it would be a tad cramped.....
i dont know how else to explain it, but any help would be nice and thanks alot if so :-)
mike
Username: Shade
Moxee, Wa
U.S.
Post Number: 658
banana clips on sub1 do the banana clip positive to positive and negative to negative. and same for the other sub.
i believe that should give u a 1ohm load, also in the manual for the subs it explains how to achieve ohm loads that u desire for upto 4 subs if i remember right.
Home > Message Board > Car Audio > Subwoofers > Archive through May 19, 2008 > Alpine Type R Wiring [ « Previous ] [ Next » ]
