Home > Message Board > Car Audio > Amplifiers > Archive through June 06, 2008 > Low idle
Author Thread: Low idle
Username: Weezer4rock
Post Number: 14
Just installed an amp in my 2000 civic. Alpine 25x4rms. The car will sometimes idle low after the install Should I be concerned that my battery life will be shortened?
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5341
weird.. check your voltage just for security.
i own a 00 civic with 1k rms and no problems at all
Username: Dupe112309
Post Number: 83
ive got a 00 mustang cpe around 1400 rms but my car seems to be takinga while to start up sometimes. without the engine running it takes about 10 minutes until my battery dies. should i be concerned?
Home > Message Board > Car Audio > Amplifiers > Archive through June 06, 2008 > Low idle [ « Previous ] [ Next » ]
